跳转到主内容
加入维修社区 - 创建账户
DualShock 2 Disassembly
你所需要的
    1. DualShock 2 Disassembly, DualShock 2 Disassembly: 步骤 1 中的图像 1,2 DualShock 2 Disassembly, DualShock 2 Disassembly: 步骤 1 中的图像 2,2
      • First, check that the connection port of your controller (whether wireless or not) has all the pins.
      • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
      添加评论
    2. DualShock 2 Disassembly: 步骤 2 中的图像 1,2 DualShock 2 Disassembly: 步骤 2 中的图像 2,2
      • Flip Over Controller and remove all 6 screws from the bottom of the controller.
      询问修复机器人
      添加评论
    3. DualShock 2 Disassembly: 步骤 3 中的图像 1,2 DualShock 2 Disassembly: 步骤 3 中的图像 2,2
      • Once the screws are removed, carefully pry the controller open with your hands.
      • Remove the screw holding the circuit board in place.
      询问修复机器人
      添加评论
    4. DualShock 2 Disassembly: 步骤 4 中的图像 1,1
      • Carefully remove the circuit board from the front cover of the controller.
      添加评论
    5. DualShock 2 Disassembly: 步骤 5 中的图像 1,1
      • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
      询问修复机器人
      添加评论
    6. DualShock 2 Disassembly: 步骤 6 中的图像 1,1
      • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
      询问修复机器人
      添加评论
    7. DualShock 2 Disassembly: 步骤 7 中的图像 1,1
      • Check the connection of the flexible trigger board to the main circuit board of your controller.
      询问修复机器人
      添加评论
    8. DualShock 2 Disassembly: 步骤 8 中的图像 1,1
      • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
      询问修复机器人
      添加评论
    9. DualShock 2 Disassembly: 步骤 9 中的图像 1,1
      • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
48等其他人完成本指南。
Peder Hertel
于09/29/15注册
1,503 声望
撰写一个指南
团队
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015 的会员
CPSU-GREEN-F15S17G5
4 名成员
创作了19篇指南
7指南评论
Dualshock 2 controllers, model A and H, are having 8 pins, not 9. Your first Step is false and rarely wires are the cause of the problem.
Eva Langley - 回复 分享
No my Dual-shock 2 controller has 9 pins so you are wrong he is right man.
Adam Bolyard - 回复 分享
Eva Langley is correct, some of these controllers have only 8 pins, not 9. I myself can conformed this because I just recently opened one of two brand new fresh out of the box Sony original equipment controllers that I purchased (for a little less than $10 a piece) during a clearance sale at my local Sears just before they went out of business. So Eva is NOT wrong. I still have the second one still in the box and before anyone ask, I don’t won’t to sale. I purchased them because I have had both my original controllers go out after they were sitting up for a few years without use. My game units are very well taken care of but the controllers of the PS2 just stopped working and finding a definitive answer to why this happens is STILL very elusive in 2019.
byordsilp - 回复 分享
After opening one of these, the R2 and L2 buttons don't feel right, is there a way to fix this?
Fridtjof Riibe - 回复 分享
Try to put R2 and L2 after you close the shell. The buttons have clips that hold on position after you insert them .
Alex SC - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 33
过去 7 天: 233
过去 30 天: 956
总计 87,721
