跳转到主内容
DualSense Controller v2 Motherboard Replacement
你所需要的
  1. DualSense Controller v2 Motherboard Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 2,2
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Motherboard Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 3,3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Motherboard Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 2,2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Motherboard Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 3,3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Motherboard Replacement, Remove the middle trim: 步骤 5 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Remove the middle trim: 步骤 5 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Remove the middle trim: 步骤 5 中的图像 3,3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Motherboard Replacement, Remove the L1 button: 步骤 6 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Remove the L1 button: 步骤 6 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Remove the L1 button: 步骤 6 中的图像 3,3
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Motherboard Replacement, Remove the R1 button: 步骤 7 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Remove the R1 button: 步骤 7 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Remove the R1 button: 步骤 7 中的图像 3,3
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Motherboard Replacement, Remove the case screws: 步骤 8 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Motherboard Replacement, Unclip the rear case: 步骤 10 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Unclip the rear case: 步骤 10 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Unclip the rear case: 步骤 10 中的图像 3,3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Motherboard Replacement, Remove the rear case: 步骤 11 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Remove the rear case: 步骤 11 中的图像 2,2
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Motherboard Replacement, Reposition the battery: 步骤 12 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Reposition the battery: 步骤 12 中的图像 2,2
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Motherboard Replacement, Disconnect the battery: 步骤 13 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Disconnect the battery: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Motherboard Replacement, Remove the battery: 步骤 14 中的图像 1,1
    • Remove the battery.
  15. DualSense Controller v2 Motherboard Replacement, Remove the lower microphone: 步骤 15 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Remove the lower microphone: 步骤 15 中的图像 2,2
    • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Motherboard Replacement: 步骤 16 中的图像 1,2 DualSense Controller v2 Motherboard Replacement: 步骤 16 中的图像 2,2
    在这个步骤中使用的工具:
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Motherboard Replacement, Remove the battery bracket: 步骤 17 中的图像 1,1
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Motherboard Replacement: 步骤 18 中的图像 1,2 DualSense Controller v2 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Motherboard Replacement, Disconnect the right trigger assembly: 步骤 19 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Disconnect the right trigger assembly: 步骤 19 中的图像 2,2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Motherboard Replacement: 步骤 20 中的图像 1,2 DualSense Controller v2 Motherboard Replacement: 步骤 20 中的图像 2,2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Motherboard Replacement, Disconnect the left trigger assembly: 步骤 21 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Disconnect the left trigger assembly: 步骤 21 中的图像 2,2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Motherboard Replacement: 步骤 22 中的图像 1,2 DualSense Controller v2 Motherboard Replacement: 步骤 22 中的图像 2,2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Motherboard Replacement, Disconnect the upper microphone: 步骤 23 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Disconnect the upper microphone: 步骤 23 中的图像 2,2
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
  24. DualSense Controller v2 Motherboard Replacement, Disconnect the touchpad: 步骤 24 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Disconnect the touchpad: 步骤 24 中的图像 2,2
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Motherboard Replacement, Lift out the motherboard: 步骤 25 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Lift out the motherboard: 步骤 25 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Lift out the motherboard: 步骤 25 中的图像 3,3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Motherboard Replacement, Desolder the vibration motor wires: 步骤 26 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Desolder the vibration motor wires: 步骤 26 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Desolder the vibration motor wires: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Flip the motherboard and midframe over to access the red and black vibration motor wires.
    • Use a soldering iron to disconnect the vibration motor wires from the motherboard.
    • To learn how to solder, or to get some helpful tips and tricks, check out our soldering guide.
    • During reassembly, refer to this photo to ensure the wires are soldered back to their correct positions.
  27. DualSense Controller v2 Motherboard Replacement, Remove the joystick covers: 步骤 27 中的图像 1,3 DualSense Controller v2 Motherboard Replacement, Remove the joystick covers: 步骤 27 中的图像 2,3 DualSense Controller v2 Motherboard Replacement, Remove the joystick covers: 步骤 27 中的图像 3,3
    • Use your fingers to remove the left and right joystick covers from the motherboard.
  28. DualSense Controller v2 Motherboard Replacement, Remove the speaker: 步骤 28 中的图像 1,2 DualSense Controller v2 Motherboard Replacement, Remove the speaker: 步骤 28 中的图像 2,2
    • Use your fingers to remove the speaker and foam pad from the motherboard.
    • Only the motherboard remains.
    • During reassembly, make sure the gold contacts on the speaker are aligned with the gold contacts on the motherboard.
结论
4等其他人完成本指南。
Sam Omiotek
于02/25/19注册
93,028 声望
创作了290篇指南
1指南评论
"Replacing the motherboard is necessary to resolve joystick drift and charging port failure." Cleaning the joysticks out with compressed air and/or rubbing alcohol can often resolve the drift issue until it needs to be cleaned again. Joystick replacement is an option without total board replacement. Controllers possibly to calibrate at startup and can be reset to calibrate as well https://osgamers.com/frequently-asked-qu...
Charge port failure definitely doesn't require a board replacement. It's the pins are small, but should be manageable with flux.
Allen Millington - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 93
过去 30 天: 392
总计 11,992
