跳转到主内容
加入维修社区 - 创建账户
Dremel 8220 Speed Selector Switch Replacement
你所需要的
    1. Dremel 8220 Speed Selector Switch Replacement, Speed selector switch: 步骤 1 中的图像 1,1
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      询问修复机器人
      添加评论
    2. Dremel 8220 Speed Selector Switch Replacement: 步骤 2 中的图像 1,1
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      询问修复机器人
      添加评论
    3. Dremel 8220 Speed Selector Switch Replacement: 步骤 3 中的图像 1,1
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      询问修复机器人
      添加评论
    4. Dremel 8220 Speed Selector Switch Replacement: 步骤 4 中的图像 1,1
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      询问修复机器人
      添加评论
    5. Dremel 8220 Speed Selector Switch Replacement: 步骤 5 中的图像 1,3 Dremel 8220 Speed Selector Switch Replacement: 步骤 5 中的图像 2,3 Dremel 8220 Speed Selector Switch Replacement: 步骤 5 中的图像 3,3
      • Remove the 5 torx screws using a t9 screwdriver head.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      询问修复机器人
      添加评论
    6. Dremel 8220 Speed Selector Switch Replacement: 步骤 6 中的图像 1,1
      • The speed selector switch is now easily accessible. Grab the switch and lift it out of the circuit board.
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G8
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 1,336
