跳转到主内容
加入维修社区 - 创建账户
Dremel 8220 Power Switch Replacement
你所需要的
  1. Dremel 8220 Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,1
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
    询问修复机器人
    添加评论
  2. Dremel 8220 Power Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
    询问修复机器人
    添加评论
  3. Dremel 8220 Power Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
    询问修复机器人
    添加评论
  4. Dremel 8220 Power Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
    询问修复机器人
    添加评论
  5. Dremel 8220 Power Switch Replacement: 步骤 5 中的图像 1,3 Dremel 8220 Power Switch Replacement: 步骤 5 中的图像 2,3 Dremel 8220 Power Switch Replacement: 步骤 5 中的图像 3,3
    • Remove five T9 Torx screws from the side of the tool.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
    询问修复机器人
    添加评论
  6. Dremel 8220 Power Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the faulty power switch. It should come out of the device without using any force.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 UMass Dartmouth, Team 2-8, Isaacson Spring 2016 的会员
UMASSD-ISAACSON-S16S2G8
3 名成员
创作了5篇指南
1指南评论
Awesome!! Thanks!
christooher t - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 2,616
