简介
This guide will show you how to replace a defective motor. With a few steps and a some tools, you will be able to open up the device and gain access to the motor. The motor can then be easily swapped out for a new one so that it can start working again.
你所需要的
Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
5等其他人完成本指南。
3指南评论
Have you ever taken apart the motor? If so how?
Micky Ashey - 回复 分享
Is there polarity correctness of the motor connections?
Yes cal, the +ve (red) wire connects to the spade marked with a red dot.
qedelectrics - 回复 分享
