跳转到主内容
加入维修社区 - 创建账户
Dragon Touch M10X Screen Replacement
你所需要的
    1. Dragon Touch M10X  Screen Replacement, Screen: 步骤 1 中的图像 1,2 Dragon Touch M10X  Screen Replacement, Screen: 步骤 1 中的图像 2,2
      • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
      询问修复机器人
      添加评论
    2. Dragon Touch M10X  Screen Replacement: 步骤 2 中的图像 1,1
      • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
      • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
      询问修复机器人
      添加评论
    3. Dragon Touch M10X  Screen Replacement: 步骤 3 中的图像 1,2 Dragon Touch M10X  Screen Replacement: 步骤 3 中的图像 2,2
      • Using your hands and the separating tool, remove the back cover from the device.
      询问修复机器人
      添加评论
    4. Dragon Touch M10X  Screen Replacement: 步骤 4 中的图像 1,2 Dragon Touch M10X  Screen Replacement: 步骤 4 中的图像 2,2
      • Using a J0 phillips head bit, remove the four 1mm screws from the speaker cover. Remove the cover and all four screws.
      询问修复机器人
      添加评论
    5. Dragon Touch M10X  Screen Replacement: 步骤 5 中的图像 1,1
      • Using a plastic opening tool, carefully peel off the yellow tape holding the battery in place.
      询问修复机器人
      添加评论
    6. Dragon Touch M10X  Screen Replacement: 步骤 6 中的图像 1,1
      • The battery is held onto the surface with a strong epoxy. The battery can be bent easily so extreme care must be taken in removing it from the surface. A plastic opening tool must be used to loosen the battery from the surface.
      • Once it is loose, it may be fully separated by using either your hands or the plastic opening tool.
      询问修复机器人
      添加评论
    7. Dragon Touch M10X  Screen Replacement: 步骤 7 中的图像 1,2 Dragon Touch M10X  Screen Replacement: 步骤 7 中的图像 2,2
      • Using a J0 phillips head bit unscrew the three 1 mm screws from the motherboard as shown. Remove all three and place them aside.
      询问修复机器人
      添加评论
    8. Dragon Touch M10X  Screen Replacement: 步骤 8 中的图像 1,1
      在这个步骤中使用的工具:
      • Using a plastic opening tool, lift up the latch that secures the right side of the motherboard to the screen's ribbon cable.
      • Using tweezers remove the screen's ribbon cable from the motherboard.
      询问修复机器人
      添加评论
    9. Dragon Touch M10X  Screen Replacement: 步骤 9 中的图像 1,1
      • Using a plastic opening tool, lift up the latch that secures the left side of the motherboard to the screen's ribbon cable.
      询问修复机器人
      添加评论
    10. Dragon Touch M10X  Screen Replacement: 步骤 10 中的图像 1,1
      • Completely remove the conjoined battery, speakers, and motherboard from the device.
      询问修复机器人
      添加评论
    11. Dragon Touch M10X  Screen Replacement: 步骤 11 中的图像 1,1
      • Once all components have been cleared out, you can pry the corners of the device screen away from the LCD panel using a plastic opening tool. Work your way around until it is loose enough to remove.
      询问修复机器人
      添加评论
    12. Dragon Touch M10X  Screen Replacement: 步骤 12 中的图像 1,1
      • Remove the LCD panel from the device screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Eric Megna
于03/24/16注册
333 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G7
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 39
总计 4,624
