简介
If you need to replace the battery of your Diswoe Switch-01 controller, follow this guide. Make sure it is disconnected from the console before you begin the repair.
你所需要的
Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
Remove the handgrips from the controller.
Push on alternating sides of the battery connector to "walk" it out of its socket.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2等其他人完成本指南。
