跳转到主内容
加入维修社区 - 创建账户
Disassembly Guide
你所需要的
    1. Disassembly Guide, Battery: 步骤 1 中的图像 1,3 Disassembly Guide, Battery: 步骤 1 中的图像 2,3 Disassembly Guide, Battery: 步骤 1 中的图像 3,3
      • Locate the battery housing cover on the bottom of your camera.
      • Place a finger on the textured portion of the battery housing cover.
      • Slide the cover in the direction that the arrow is pointing.
      询问修复机器人
      添加评论
    2. Disassembly Guide: 步骤 2 中的图像 1,2 Disassembly Guide: 步骤 2 中的图像 2,2
      • Use your finger to pivot the orange tab away from the battery.
      询问修复机器人
      添加评论
    3. Disassembly Guide: 步骤 3 中的图像 1,1
      • Pull the battery out of the housing with your fingers.
      询问修复机器人
      添加评论
    1. Disassembly Guide, Motherboard: 步骤 4 中的图像 1,2 Disassembly Guide, Motherboard: 步骤 4 中的图像 2,2
      • Remove the two 4mm Hex screws that connect the grip to the camera with a Hex head screwdriver.
      • Remove the two Phillips screws to the left of the hex screws with a Phillips head screwdriver:
      • One 2mm screw
      • One 3mm screw
      • Remove the grip from the front of the camera by pulling it away from the lens and then away from the camera.
      添加评论
    2. Disassembly Guide: 步骤 5 中的图像 1,1
      • Remove the following three Philips screws from the flash release side of the camera with a Philips Head screwdriver:
      • One 2.5mm screw
      • One 4.5mm screw
      • One 1.75mm screw
      添加评论
    3. Disassembly Guide: 步骤 6 中的图像 1,1
      • Remove the following three Philips screws from the bottom of the camera with a Philips Head screwdriver:
      • One 3.25mm screw
      • One 2.5mm screw
      • One 2.75mm screw
      添加评论
    4. Disassembly Guide: 步骤 7 中的图像 1,2 Disassembly Guide: 步骤 7 中的图像 2,2
      • Rotate the LCD screen away from the camera.
      询问修复机器人
      添加评论
    5. Disassembly Guide: 步骤 8 中的图像 1,1
      • Remove the following four Phillips screws securing the back panel with a Philips Head screwdriver:
      • Two 3 mm screws
      • One 2mm screw
      • One 2.5 mm screw
      添加评论
    6. Disassembly Guide: 步骤 9 中的图像 1,1
      • Lift the back casing up far enough to expose the ribbon cables.
      询问修复机器人
      添加评论
    7. Disassembly Guide: 步骤 10 中的图像 1,2 Disassembly Guide: 步骤 10 中的图像 2,2
      • Use a plastic spudger to gently release the locking tab holding the ribbon cable, closest to the edge of the camera, in place.
      • Repeat this process for the second ribbon cable to the right.
      • Carefully lift the back casing away from the camera.
      询问修复机器人
      添加评论
    8. Disassembly Guide: 步骤 11 中的图像 1,1
      询问修复机器人
      添加评论
    9. Disassembly Guide: 步骤 12 中的图像 1,2 Disassembly Guide: 步骤 12 中的图像 2,2
      • Remove the five Phillips screws that are attached to the copper plate with a Philips Head screwdriver:
      • Two 3mm screws
      • Two 1.5mm screws
      • One 4mm screw
      • Lift the copper plate away from the camera.
      询问修复机器人
      添加评论
    10. Disassembly Guide: 步骤 13 中的图像 1,3 Disassembly Guide: 步骤 13 中的图像 2,3 Disassembly Guide: 步骤 13 中的图像 3,3
      • Remove the following three Phillips screws securing the silver plate with a Philips Head screwdriver:
      • Two 2.9mm screws on the front of the camera
      • One 1.8mm screw on the bottom of the camera
      • Lift the silver plate away from the camera.
      询问修复机器人
      添加评论
    11. Disassembly Guide: 步骤 14 中的图像 1,2 Disassembly Guide: 步骤 14 中的图像 2,2
      • Use the plastic spudger to lift up both sides of the ribbon cable from its connector pins.
      • The male end is on the left and the female end is on the right. The right side of the cable is notched.
      询问修复机器人
      添加评论
    12. Disassembly Guide: 步骤 15 中的图像 1,3 Disassembly Guide: 步骤 15 中的图像 2,3 Disassembly Guide: 步骤 15 中的图像 3,3
      • Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
      • Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
      • Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
      • Both ribbon cables should be removed after this step.
      询问修复机器人
      添加评论
    13. Disassembly Guide: 步骤 16 中的图像 1,2 Disassembly Guide: 步骤 16 中的图像 2,2
      • Release the flash by sliding the flash release towards the lens.
      • The flash release is located on the side of the camera closest to the lens.
      询问修复机器人
      添加评论
    14. Disassembly Guide: 步骤 17 中的图像 1,2 Disassembly Guide: 步骤 17 中的图像 2,2
      • Remove the following two Phillips screws from the flash cavity with a Philips Head screwdriver:
      • Remove the 2mm screw to the right of the flash.
      • Remove the 2.5mm screw to the left of the flash.
      询问修复机器人
      添加评论
    15. Disassembly Guide: 步骤 18 中的图像 1,2 Disassembly Guide: 步骤 18 中的图像 2,2
      • Remove the 2.5mm Phillips screw from the front plate with a Phillips head screwdriver.
      • Pull up on the top portion of the camera to separate the top casing from the camera body.
      • Make sure the flash is up. Otherwise the top casing will not release.
      添加评论
    16. Disassembly Guide: 步骤 19 中的图像 1,2 Disassembly Guide: 步骤 19 中的图像 2,2
      • Remove the 3.5mm Phillips screw from the grey tab on the top of the camera with a Philips Head screwdriver.
      • Rotate the camera so the back panel is facing you.
      • Remove the 1.4mm Phillips screw from the sliver tab near the top of the camera with a Philips Head screwdriver.
      添加评论
    17. Disassembly Guide: 步骤 20 中的图像 1,2 Disassembly Guide: 步骤 20 中的图像 2,2
      • Use the flat end of the plastic spudger to release the plastic retaining clip on the side plate closest to the lens.
      • Rotate the side plate closest to the lens toward the lens of the camera and then pull the plate away from the camera.
      询问修复机器人
      添加评论
    18. Disassembly Guide: 步骤 21 中的图像 1,3 Disassembly Guide: 步骤 21 中的图像 2,3 Disassembly Guide: 步骤 21 中的图像 3,3
      在这个步骤中使用的工具:
      • Release the plastic locking tab of the upper ribbon cable with the plastic spudger.
      • Pull the top ribbon cable from its mount with the fine tip metal tweezers.
      • Remove the bottom ribbon cable with the fine tip metal tweezers by pulling it toward the flash switch side of the camera.
      • The bottom ribbon cable does not have a locking tab; it simply slides in and out.
      询问修复机器人
      添加评论
    19. Disassembly Guide: 步骤 22 中的图像 1,1
      • Pull the front plate off the camera body.
      • It should slide off easily. If it does not, ensure that all screws and ribbon cables from previous steps have been removed or disconnected.
      询问修复机器人
      添加评论
    20. Disassembly Guide: 步骤 23 中的图像 1,1
      • Remove the rubber dust cover from the camera by moving the hooks away from the three prongs holding them in place and then pulling the cover away from the camera.
      询问修复机器人
      添加评论
    21. Disassembly Guide: 步骤 24 中的图像 1,2 Disassembly Guide: 步骤 24 中的图像 2,2
      • Remove the following two Phillips screws from the side of the camera with the three connector ports with a Phillips head screwdriver:
      • One 2.5mm screw
      • One 3.3mm screw
      • Pull the metal shield away from the camera.
      询问修复机器人
      添加评论
    22. Disassembly Guide: 步骤 25 中的图像 1,3 Disassembly Guide: 步骤 25 中的图像 2,3 Disassembly Guide: 步骤 25 中的图像 3,3
      • Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
      • Remove the 2.8mm screw from the motherboard.
      • Do not try to remove the motherboard from the camera yet.
      • Carefully rotate the motherboard upward.
      • Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
      询问修复机器人
      添加评论
    23. Disassembly Guide: 步骤 26 中的图像 1,1
      • Lift the motherboard away from the camera.
      询问修复机器人
      添加评论
    1. Disassembly Guide, Lens: 步骤 27 中的图像 1,3 Disassembly Guide, Lens: 步骤 27 中的图像 2,3 Disassembly Guide, Lens: 步骤 27 中的图像 3,3
      • Lay the camera on a flat surface while performing these steps because removing the frame causes the camera to fall apart.
      • Remove the four 4.25mm Philips screws from the silver frame that surrounds the lens of the camera with a Philips Head screwdriver.
      • Remove the frame by lifting straight up.
      询问修复机器人
      添加评论
    2. Disassembly Guide: 步骤 28 中的图像 1,1
      • Separate the lens from the other components of the camera.
      询问修复机器人
      添加评论
    1. Disassembly Guide, Disassembly Guide: 步骤 29 中的图像 1,1
      • You have disassembled the Canon PowerShot G1 X Mark II!
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Ryan Dunn
于01/12/16注册
578 声望
创作了3篇指南
团队
Cal Poly, Team 70-2, Forte Winter 2016 Cal Poly, Team 70-2, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G2
4 名成员
创作了4篇指南
5指南评论
Surely these are JIS screws not Phillips. A Phillips screwdriver will chew the heads up.
maico61 - 回复 分享
I have an LCD display problem and would like to disassemble it, the guide does not cover anything to do with the LDC assembly, otherwise a very good guide. I’ll attempt it anyway once I feel like a risk.
Alan Cattalon - 回复 分享
Fabuloso. La pantalla de mi camara canon gx1 cuando la invertias se apagaba. Lo que he hecho fue comprar un cable ribbon nuevo en aliexpress y substituirlo. Asunto arreglado por 7euros.
En este tutorial, falta como desmontar la pantalla. Para hacerlo debes retirar los tornillos de la pantalla con delicadeza, despegar el cable con delicadeza y montar la pantalla otra vez.
MIGUEL A. MARTINEZ GOMEZ - 回复 分享
hola miguel angel, cual es ese cable? podrias enlazarlo, mi pantalla da fallos y debe ser ese ribbon. gracias!
alvarezrodriguezrc - 回复 分享
Thanks for this great guide ! I need to disassemble and clean the external flash connector in the top portion of the camera because of some dirt and even corrosion - I found no way how to do this, I removed all screws but I was not able to remove the metallic structure. Any idea to take this apart ? thanks in advance...
M Df - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 64
总计 11,916
