跳转到主内容
Disassembling the Teac DC-D2831
你所需要的
  1. Disassembling the Teac DC-D2831, Disassembling the Teac DC-D2831: 步骤 1 中的图像 1,1
    • Make sure the device is turned off and unplugged. This will eliminate the danger of getting electrocuted while repairing the device or damaging components.
  2. Disassembling the Teac DC-D2831: 步骤 2 中的图像 1,2 Disassembling the Teac DC-D2831: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Lift the lid to get to the turntable.
    • Using the appropriate tools (needle-nose pliers, tweezers, screwdriver, etc.), remove the snap ring from the center of the turntable. The snap-ring is the small metal ring around the axel of the turntable.
    • The snap-ring is hard to remove so be patient and don't be afraid to use some force.
    • Feel free to use whatever tool(s) that will remove the snap-ring. The above list of tools are just a suggestions.
  3. Disassembling the Teac DC-D2831: 步骤 3 中的图像 1,2 Disassembling the Teac DC-D2831: 步骤 3 中的图像 2,2
    • Gently lift the turntable from the rest of the device.
    • If the device has a faulty belt, see the belt repair guide here: Belt Repair Guide
  4. Disassembling the Teac DC-D2831: 步骤 4 中的图像 1,1
    • Remove the screws on the side of the device using a Phillips #2 screwdriver.
    • When removing the screws, take note of which screws go where.
    • 27.0mm
    • 19.8mm
    • 12.0mm
  5. Disassembling the Teac DC-D2831: 步骤 5 中的图像 1,2 Disassembling the Teac DC-D2831: 步骤 5 中的图像 2,2
    • Lift the base that the turntable was resting on from the rest of the device.
    • Remove the base slowly so to not sever the connection with the wire attached from the base to the circuit board.
  6. Disassembling the Teac DC-D2831: 步骤 6 中的图像 1,1
结论
3等其他人完成本指南。
Jake Hamilton
于09/19/12注册
167 声望
创作了2篇指南
团队
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G61
4 名成员
创作了5篇指南
2条评论
How to remove lid from CD-D2831
jfranklinhamm - 回复
So radio sound and tape work and sound is great. However when turn table is on the sound is low only on that component any help would be greatly appreciated
Joanna Chavez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 4,685
