跳转到主内容
加入维修社区 - 创建账户
Disassembling the Linksys E1200
你所需要的
    1. Disassembling the Linksys E1200, Cover and Circuit Board: 步骤 1 中的图像 1,3 Disassembling the Linksys E1200, Cover and Circuit Board: 步骤 1 中的图像 2,3 Disassembling the Linksys E1200, Cover and Circuit Board: 步骤 1 中的图像 3,3
      • Opening the device will void your warranty.
      • Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
      • Remove the three screws.
      • Save the pads for reassembly.
      询问修复机器人
      添加评论
    2. Disassembling the Linksys E1200: 步骤 2 中的图像 1,3 Disassembling the Linksys E1200: 步骤 2 中的图像 2,3 Disassembling the Linksys E1200: 步骤 2 中的图像 3,3
      • Once the three screws are removed, the device is ready for disassembly.
      • Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
      • Insert the plastic opening tool in the gap and begin prying on the corner.
      • Continue to pry around the body of the case. Separate both sides of the case with this method.
      询问修复机器人
      添加评论
    3. Disassembling the Linksys E1200: 步骤 3 中的图像 1,2 Disassembling the Linksys E1200: 步骤 3 中的图像 2,2
      • Once the sides are released, the front of the cover can be removed.
      • Use a plastic opening tool to separate the front of the cover from the body.
      • It is helpful to use a different plastic opening tool as a wedge on the sides to prevent them from snapping back together.
      询问修复机器人
      添加评论
    4. Disassembling the Linksys E1200: 步骤 4 中的图像 1,3 Disassembling the Linksys E1200: 步骤 4 中的图像 2,3 Disassembling the Linksys E1200: 步骤 4 中的图像 3,3
      • The cover can now be removed.
      • To repair anything on the circuit board, use the plastic opening tool to pull back on the two tabs holding it down.
      • Use caution when pulling on the tabs as they are stiff and easy to break.
      • Keep the tabs if they snap off. The tabs can be reattached with glue when reassembling the device.
      询问修复机器人
      添加评论
    5. Disassembling the Linksys E1200: 步骤 5 中的图像 1,3 Disassembling the Linksys E1200: 步骤 5 中的图像 2,3 Disassembling the Linksys E1200: 步骤 5 中的图像 3,3
      • If the antenna needs to be disconnected, desolder the connection and reattach it prior to reassembly.
      • If the ethernet ports, power port, or reset button are damaged, the large solder points allow you to replace them.
      • Many components on the board cannot be serviced. These components were attached by a machine and cannot be removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
团队
Michigan Tech, Team 5-4, Lauer Spring 2014 Michigan Tech, Team 5-4, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G4
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 49
总计 7,748
