跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的iClicker,应参考我们的维修指南
  1. Disassembling iClicker Device, Disassembling iClicker Device: 步骤 1 中的图像 1,1
    • Behold the iclicker in all its interactive and educational beauty.
    询问修复机器人
    添加评论
  2. Disassembling iClicker Device: 步骤 2 中的图像 1,1
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
    询问修复机器人
    添加评论
  3. Disassembling iClicker Device: 步骤 3 中的图像 1,2 Disassembling iClicker Device: 步骤 3 中的图像 2,2
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
    询问修复机器人
    添加评论
  4. Disassembling iClicker Device: 步骤 4 中的图像 1,2 Disassembling iClicker Device: 步骤 4 中的图像 2,2
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
    询问修复机器人
    添加评论
  5. Disassembling iClicker Device: 步骤 5 中的图像 1,1
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
    询问修复机器人
    添加评论
  6. Disassembling iClicker Device: 步骤 6 中的图像 1,2 Disassembling iClicker Device: 步骤 6 中的图像 2,2
    • Using a spudger, gently pry the battery connectors from the front panel.
    询问修复机器人
    添加评论
  7. Disassembling iClicker Device: 步骤 7 中的图像 1,1
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
    询问修复机器人
    添加评论
  8. Disassembling iClicker Device: 步骤 8 中的图像 1,1
    • The buttons can be easily removed from the front assembly sans spudger.
    询问修复机器人
    添加评论
  9. Disassembling iClicker Device: 步骤 9 中的图像 1,1
    • Don't lose the small LED cover sitting precariously in the front panel.
    询问修复机器人
    添加评论
  10. Disassembling iClicker Device: 步骤 10 中的图像 1,1
    • Your iclicker is now disassembled.
    询问修复机器人
    添加评论
1指南评论
What is an iClicker ?
furbies - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 8,202
