跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Oregon Scientific Ultra Thin Weather Station,应参考我们的维修指南
  1. Disassembling Weather Box Oregon BAR800, Disassembling Weather Box Oregon BAR800: 步骤 1 中的图像 1,1
    • Weather Box, front side
    询问修复机器人
    添加评论
  2. Disassembling Weather Box Oregon BAR800: 步骤 2 中的图像 1,3 Disassembling Weather Box Oregon BAR800: 步骤 2 中的图像 2,3 Disassembling Weather Box Oregon BAR800: 步骤 2 中的图像 3,3
    • Rear side
    询问修复机器人
    添加评论
  3. Disassembling Weather Box Oregon BAR800: 步骤 3 中的图像 1,1
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
    询问修复机器人
    添加评论
  4. Disassembling Weather Box Oregon BAR800: 步骤 4 中的图像 1,3 Disassembling Weather Box Oregon BAR800: 步骤 4 中的图像 2,3 Disassembling Weather Box Oregon BAR800: 步骤 4 中的图像 3,3
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
    询问修复机器人
    添加评论
  5. Disassembling Weather Box Oregon BAR800: 步骤 5 中的图像 1,1
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
    询问修复机器人
    添加评论
  6. Disassembling Weather Box Oregon BAR800: 步骤 6 中的图像 1,3 Disassembling Weather Box Oregon BAR800: 步骤 6 中的图像 2,3 Disassembling Weather Box Oregon BAR800: 步骤 6 中的图像 3,3
    • Internal view
    询问修复机器人
    添加评论
Andres
于11/14/13注册
110 声望
撰写一个指南
10指南评论
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - 回复 分享
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel - 回复 分享
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic - 回复 分享
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V - 回复 分享
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 39
总计 3,882
