跳转到主内容
加入维修社区 - 创建账户
Disassembling REL T5 Transformer
你所需要的
  1. Disassembling REL T5 Transformer, Remove screws: 步骤 1 中的图像 1,3 Disassembling REL T5 Transformer, Remove screws: 步骤 1 中的图像 2,3 Disassembling REL T5 Transformer, Remove screws: 步骤 1 中的图像 3,3
    • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
    • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
    • Make sure to support the plate amp by gripping the heat sink.
    • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
    • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
    询问修复机器人
    添加评论
  2. Disassembling REL T5 Transformer, Disconnect the driver: 步骤 2 中的图像 1,2 Disassembling REL T5 Transformer, Disconnect the driver: 步骤 2 中的图像 2,2
    • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
    询问修复机器人
    添加评论
  3. Disassembling REL T5 Transformer, Remove plate amp: 步骤 3 中的图像 1,1
    • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
    • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
    询问修复机器人
    添加评论
  4. Disassembling REL T5 Transformer, Snip all connecting trywraps: 步骤 4 中的图像 1,2 Disassembling REL T5 Transformer, Snip all connecting trywraps: 步骤 4 中的图像 2,2
    • Snip all tywraps, such that all cables can be manipulated freely.
    询问修复机器人
    添加评论
  5. Disassembling REL T5 Transformer, Disconnect connectors: 步骤 5 中的图像 1,2 Disassembling REL T5 Transformer, Disconnect connectors: 步骤 5 中的图像 2,2
    • Disconnect all connectors that tie to the transformer
    • Make sure that all leads can be manipulated freely.
    询问修复机器人
    添加评论
  6. Disassembling REL T5 Transformer, Loosen screws: 步骤 6 中的图像 1,2 Disassembling REL T5 Transformer, Loosen screws: 步骤 6 中的图像 2,2
    • Start loosening the screws on the back using the m3 hex tool
    • Don't remove them fully, yet though.
    询问修复机器人
    添加评论
  7. Disassembling REL T5 Transformer, Remove screws: 步骤 7 中的图像 1,2 Disassembling REL T5 Transformer, Remove screws: 步骤 7 中的图像 2,2
    • Turn the amp on it's back.
    • Remove the nuts from the screws that where loosened on the back.
    • Remove the philips screws using a #2.
    询问修复机器人
    添加评论
  8. Disassembling REL T5 Transformer, Loosen dampening rubber: 步骤 8 中的图像 1,1
    • Loosen the dampening rubber by running a Halberd Spudger underneath it.
    • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
    询问修复机器人
    添加评论
  9. Disassembling REL T5 Transformer, Remove transformer: 步骤 9 中的图像 1,2 Disassembling REL T5 Transformer, Remove transformer: 步骤 9 中的图像 2,2
    • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 18
总计 27
