跳转到主内容
加入维修社区 - 创建账户
Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
你所需要的
视频概述
    1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: 步骤 1 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: 步骤 1 中的图像 2,2
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
      询问修复机器人
      添加评论
    2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 2 中的图像 1,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 2 中的图像 2,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 2 中的图像 3,3
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
      添加评论
    3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 3 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 3 中的图像 2,2
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
      询问修复机器人
      添加评论
    4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 4 中的图像 1,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 4 中的图像 2,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 4 中的图像 3,3
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
      询问修复机器人
      添加评论
    5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 5 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 5 中的图像 2,2
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
      添加评论
    6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 6 中的图像 1,1
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
      添加评论
    7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 7 中的图像 1,1
      • Free the battery cable by gently prying up on the connection with a spudger.
      添加评论
    8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 8 中的图像 1,1
      • Separate the front and rear cases.
      询问修复机器人
      添加评论
    1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: 步骤 9 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: 步骤 9 中的图像 2,2
      • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
      • The easiest access to the battery cable retainer is where the battery cable comes out.
      • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
      添加评论
    2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 10 中的图像 1,2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 10 中的图像 2,2
      • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
      • Remove the plastic battery retaining bar.
      添加评论
    3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 11 中的图像 1,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 11 中的图像 2,3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 步骤 11 中的图像 3,3
      • Using your finger or a spudger, lift the battery out and remove it.
      • Guide the battery wires through the hole in the back casing as you remove the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
djgodmandj
于10/24/14注册
302 声望
撰写一个指南
1指南评论
So is there any chance that this could be used as a modding possibility, where we could install a higher resolution /quality screen?
TheHeavy - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 56
过去 30 天: 230
总计 10,269
