跳转到主内容
加入维修社区 - 创建账户
Disassembling Olympus Stylus 725 SW Back Panel
你所需要的
  1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: 步骤 1 中的图像 1,2 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: 步骤 1 中的图像 2,2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
    询问修复机器人
    添加评论
  2. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 2 中的图像 1,3 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 2 中的图像 2,3 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 2 中的图像 3,3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  3. Disassembling Olympus Stylus 725 SW Back Panel: 步骤 3 中的图像 1,2 Disassembling Olympus Stylus 725 SW Back Panel: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Bobby Hodges
于04/18/10注册
49 声望
创作了6篇指南
团队
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G71
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 49
总计 4,989
