跳转到主内容
加入维修社区 - 创建账户
Disassembling Nokia E61i Volume Control Buttons
你所需要的
    1. Disassembling Nokia E61i Volume Control Buttons, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia E61i Volume Control Buttons, Battery: 步骤 1 中的图像 2,2
      • First, gather all necessary tools.
      • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
      • Slide the back cover downwards off of the phone while pressing down on the tab.
      询问修复机器人
      添加评论
    2. Disassembling Nokia E61i Volume Control Buttons: 步骤 2 中的图像 1,1
      • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
      询问修复机器人
      添加评论
    3. Disassembling Nokia E61i Volume Control Buttons: 步骤 3 中的图像 1,1
      • Lift the battery out using your finger.
      • The E61i uses a Nokia BP-4L standard battery.
      询问修复机器人
      添加评论
    1. Disassembling Nokia E61i Volume Control Buttons, Front Cover: 步骤 4 中的图像 1,2 Disassembling Nokia E61i Volume Control Buttons, Front Cover: 步骤 4 中的图像 2,2
      • To remove the top of the back cover, pry the sides and pop it off.
      • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
      询问修复机器人
      添加评论
    2. Disassembling Nokia E61i Volume Control Buttons: 步骤 5 中的图像 1,1
      • Remove the cover by pulling it up and off.
      询问修复机器人
      添加评论
    1. Disassembling Nokia E61i Volume Control Buttons, Display: 步骤 6 中的图像 1,2 Disassembling Nokia E61i Volume Control Buttons, Display: 步骤 6 中的图像 2,2
      • Take off the casing and keyboard.
      • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
      • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
      • Lift the ribbon, disconnecting contact with the motherboard.
      • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
      询问修复机器人
      添加评论
    2. Disassembling Nokia E61i Volume Control Buttons: 步骤 7 中的图像 1,2 Disassembling Nokia E61i Volume Control Buttons: 步骤 7 中的图像 2,2
      • Gently pull the screen off of the phone.
      • Be sure not to rip the sticker that connects the display and the motherboard.
      • Pull the silver case off to completely free the cracked or damaged screen.
      询问修复机器人
      添加评论
    1. Disassembling Nokia E61i Volume Control Buttons, Motherboard: 步骤 8 中的图像 1,3 Disassembling Nokia E61i Volume Control Buttons, Motherboard: 步骤 8 中的图像 2,3 Disassembling Nokia E61i Volume Control Buttons, Motherboard: 步骤 8 中的图像 3,3
      • Pull the green motherboard from the back casing.
      询问修复机器人
      添加评论
    1. Disassembling Nokia E61i Volume Control Buttons, Volume Control Buttons: 步骤 9 中的图像 1,1
      • The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
      询问修复机器人
      添加评论
    2. Disassembling Nokia E61i Volume Control Buttons: 步骤 10 中的图像 1,1
      • Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G63
5 名成员
创作了144篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 2,028
