跳转到主内容
加入维修社区 - 创建账户
Disassembling Nokia 2366i Motherboard
你所需要的
    1. Disassembling Nokia 2366i Motherboard, Battery: 步骤 1 中的图像 1,2 Disassembling Nokia 2366i Motherboard, Battery: 步骤 1 中的图像 2,2
      • Turn off the phone.
      • Position the phone so that the back side is in view.
      询问修复机器人
      添加评论
    2. Disassembling Nokia 2366i Motherboard: 步骤 2 中的图像 1,1
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
      询问修复机器人
      添加评论
    3. Disassembling Nokia 2366i Motherboard: 步骤 3 中的图像 1,3 Disassembling Nokia 2366i Motherboard: 步骤 3 中的图像 2,3 Disassembling Nokia 2366i Motherboard: 步骤 3 中的图像 3,3
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
      询问修复机器人
      添加评论
    1. Disassembling Nokia 2366i Motherboard, Rear Case: 步骤 4 中的图像 1,2 Disassembling Nokia 2366i Motherboard, Rear Case: 步骤 4 中的图像 2,2
      • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
      询问修复机器人
      添加评论
    2. Disassembling Nokia 2366i Motherboard: 步骤 5 中的图像 1,2 Disassembling Nokia 2366i Motherboard: 步骤 5 中的图像 2,2
      • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
      • 2 screws at the bottom
      • 2 screws at the top
      询问修复机器人
      添加评论
    3. Disassembling Nokia 2366i Motherboard: 步骤 6 中的图像 1,2 Disassembling Nokia 2366i Motherboard: 步骤 6 中的图像 2,2
      • Rotate the phone clockwise so the edge is facing you.
      • Insert the spudger in tabs between the outer casing and the inside frame.
      • Slide the spudger upwards.
      • This will remove the rear case of the phone.
      询问修复机器人
      添加评论
    4. Disassembling Nokia 2366i Motherboard: 步骤 7 中的图像 1,1
      • The phone should now be in two different sections.
      • 1) The rear case of the phone.
      • 2) The motherboard and the rest of the phone.
      询问修复机器人
      添加评论
    1. Disassembling Nokia 2366i Motherboard, Motherboard: 步骤 8 中的图像 1,2 Disassembling Nokia 2366i Motherboard, Motherboard: 步骤 8 中的图像 2,2
      • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
      询问修复机器人
      添加评论
    2. Disassembling Nokia 2366i Motherboard: 步骤 9 中的图像 1,2 Disassembling Nokia 2366i Motherboard: 步骤 9 中的图像 2,2
      • Rotate the phone counterclockwise so that the edge is facing you.
      • Use the spudger to lift the motherboard out of the base of the phone.
      • Remove the motherboard from the base of the phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 1-14, Amido Winter 2011 Cal Poly, Team 1-14, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G14
5 名成员
创作了36篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 1,935
