跳转到主内容
加入维修社区 - 创建账户
Disassembling Netatmo Outdoor Camera Main Unit
你所需要的
  1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: 步骤 1 中的图像 1,2 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: 步骤 1 中的图像 2,2
    • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
    • The panel will lift up and can be removed.
    询问修复机器人
    添加评论
  2. Disassembling Netatmo Outdoor Camera Main Unit: 步骤 2 中的图像 1,2 Disassembling Netatmo Outdoor Camera Main Unit: 步骤 2 中的图像 2,2
    • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
    • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
    • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
    询问修复机器人
    添加评论
  3. Disassembling Netatmo Outdoor Camera Main Unit: 步骤 3 中的图像 1,2 Disassembling Netatmo Outdoor Camera Main Unit: 步骤 3 中的图像 2,2
    • Remove the six 2.5mm hex screws using a long Allen key.
    • One screw has an earthing ring wire. Don't forget this when reassembling.
    询问修复机器人
    添加评论
  4. Disassembling Netatmo Outdoor Camera Main Unit: 步骤 4 中的图像 1,2 Disassembling Netatmo Outdoor Camera Main Unit: 步骤 4 中的图像 2,2
    • Separate the two pieces by pulling slightly on the lower module.
    • Pull the metal housing forward.
    • Pushing the light from the inside can help in removing the shell.
    询问修复机器人
    添加评论
  5. Disassembling Netatmo Outdoor Camera Main Unit: 步骤 5 中的图像 1,1
    • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
    询问修复机器人
    添加评论
  6. Disassembling Netatmo Outdoor Camera Main Unit: 步骤 6 中的图像 1,2 Disassembling Netatmo Outdoor Camera Main Unit: 步骤 6 中的图像 2,2
    • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
    • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
    • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 121
总计 1,202
