跳转到主内容
加入维修社区 - 创建账户
Disassembling Motorola i265 Rear Casing/Battery/SIM Card
你所需要的
  1. Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: 步骤 1 中的图像 1,2 Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: 步骤 1 中的图像 2,2
    • Press thumb against the top of the rear casing as shown and push down as you slide the casing off of the body.
    • You should hear a click as the latches on the casing disengage.
    询问修复机器人
    添加评论
  2. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 步骤 2 中的图像 1,3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 步骤 2 中的图像 2,3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 步骤 2 中的图像 3,3
    • To remove the battery, press thumb against the bottom edge of the battery and push towards the top of the phone.
    • Then, lift the bottom edge of the battery upwards out of the body. Gently pull the battery towards yourself, and out of the phone.
    询问修复机器人
    添加评论
  3. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 步骤 3 中的图像 1,3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 步骤 3 中的图像 2,3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: 步骤 3 中的图像 3,3
    • To remove SIM card, press thumb against tab marked “PUSH.”
    • While still pressing the PUSH tab, gently press spduger into the groove between the top of the SIM card and the body. Use spudger to slide SIM card toward the PUSH tab, so that when the spudger reaches the metal cover, the card itself is depressing the tab.
    • Press your thumb against the exposed section of the SIM card, and slide it towards the rear of the phone until it is completely free of the metal cover.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 6-15, Maness Spring 2010 Cal Poly, Team 6-15, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G15
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 2,890
