跳转到主内容
加入维修社区 - 创建账户
Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
你所需要的
    1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: 步骤 1 中的图像 1,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: 步骤 1 中的图像 2,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: 步骤 1 中的图像 3,3
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      询问修复机器人
      添加评论
    2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: 步骤 2 中的图像 1,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: 步骤 2 中的图像 2,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: 步骤 2 中的图像 3,3
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      询问修复机器人
      添加评论
    1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: 步骤 3 中的图像 1,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: 步骤 3 中的图像 2,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: 步骤 3 中的图像 3,3
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      询问修复机器人
      添加评论
    2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: 步骤 4 中的图像 1,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: 步骤 4 中的图像 2,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: 步骤 4 中的图像 3,3
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      询问修复机器人
      添加评论
    3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: 步骤 5 中的图像 1,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: 步骤 5 中的图像 2,3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: 步骤 5 中的图像 3,3
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G9
2 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 2,437
