跳转到主内容
加入维修社区 - 创建账户
Disassembling Mac Powerbook 140 Keycaps
你所需要的
  1. Disassembling Mac Powerbook 140 Keycaps, Takeing the caps off: 步骤 1 中的图像 1,1
    • The keycaps are connected via 2 clips on the left and the right side of the keycaps. Larger keycaps are connected to stabilizers, be careful when taking these caps off since the underlying plastic has overhangs that can break off.
    • Firstly pry the clip on one side with a spudger. Keep the open clip up while prying the other clip open. Be careful of the stabilizers when taking off larger caps.
    询问修复机器人
    添加评论
  2. Disassembling Mac Powerbook 140 Keycaps, Take off underlying parts: 步骤 2 中的图像 1,1
    • The board still has the white springs and the silicone cone on it. Grab the white spring with tweezers or by hand and take it off. It has 2 clips on the top and on the bottom.
    • After removing the white part remove the silicone cone with tweezers.
    询问修复机器人
    添加评论
  3. Disassembling Mac Powerbook 140 Keycaps, Putting the silicone rings back: 步骤 3 中的图像 1,1
    • First put the silicone rings on the circular pillars with a hole. Put the silicone rings with their widest part up.
    询问修复机器人
    添加评论
    • I found the easiest way to put these back is to put it on rotated to the left then spin it clockwise until it clicks.
    询问修复机器人
    添加评论
  4. Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: 步骤 5 中的图像 1,2 Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: 步骤 5 中的图像 2,2
    • To correctly orient the keycaps note, that the letters are on the bottom left of the keycaps. Also, the caps are rounder at the bottom. You can find the place for the white spring's arms on the back side of the keycaps.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow from the 3rd step.
取消:我没有完成这个指南。
Kristóf Kékesi
于12/16/25注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 58
