跳转到主内容
加入维修社区 - 创建账户
Disassembling JVC GR-D290U
你所需要的
    1. Disassembling JVC GR-D290U, JVC GR-D290U: 步骤 1 中的图像 1,2 Disassembling JVC GR-D290U, JVC GR-D290U: 步骤 1 中的图像 2,2
      • Open the liquid-crystal display (LCD) screen.
      • Using a Phillips #1 screwdriver, remove the two hinge screws.
      • Remove the hinge cover. Shut the screen after the cover is removed.
      询问修复机器人
      添加评论
    2. Disassembling JVC GR-D290U: 步骤 2 中的图像 1,3 Disassembling JVC GR-D290U: 步骤 2 中的图像 2,3 Disassembling JVC GR-D290U: 步骤 2 中的图像 3,3
      • Flip the camera over to look at the bottom panel.
      • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
      • Push the eject button beneath the bottom panel to open the cassette cover.
      • Shut the cassette cover.
      • Place the camera upright.
      询问修复机器人
      添加评论
    3. Disassembling JVC GR-D290U: 步骤 3 中的图像 1,1
      • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
      • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
      • Replace the dark gray tab and close the LCD screen.
      询问修复机器人
      添加评论
    4. Disassembling JVC GR-D290U: 步骤 4 中的图像 1,1
      • Go to the side of the camera that is opposite the LCD screen.
      • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    5. Disassembling JVC GR-D290U: 步骤 5 中的图像 1,2 Disassembling JVC GR-D290U: 步骤 5 中的图像 2,2
      • Go to the side of the camera that has the LCD screen.
      • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
      • Pry the top cover from the bottom cover until you hear a snapping sound.
      • Gently remove the top cover from the camera base.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
justin chen
于04/27/10注册
47 声望
创作了3篇指南
团队
Cal Poly, Team 18-69, Johann Spring 2010 Cal Poly, Team 18-69, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G69
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 39
总计 4,680
