跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM WorkPad c3 Front Case
你所需要的
    1. Disassembling IBM WorkPad c3 Front Case, Back Case: 步骤 1 中的图像 1,2 Disassembling IBM WorkPad c3 Front Case, Back Case: 步骤 1 中的图像 2,2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      询问修复机器人
      添加评论
    2. Disassembling IBM WorkPad c3 Front Case: 步骤 2 中的图像 1,1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      询问修复机器人
      添加评论
    3. Disassembling IBM WorkPad c3 Front Case: 步骤 3 中的图像 1,2 Disassembling IBM WorkPad c3 Front Case: 步骤 3 中的图像 2,2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      询问修复机器人
      添加评论
    1. Disassembling IBM WorkPad c3 Front Case, Front Case: 步骤 4 中的图像 1,2 Disassembling IBM WorkPad c3 Front Case, Front Case: 步骤 4 中的图像 2,2
      • Turn the device over, so that the screen is laying on a flat surface.
      询问修复机器人
      添加评论
    2. Disassembling IBM WorkPad c3 Front Case: 步骤 5 中的图像 1,3 Disassembling IBM WorkPad c3 Front Case: 步骤 5 中的图像 2,3 Disassembling IBM WorkPad c3 Front Case: 步骤 5 中的图像 3,3
      • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
      • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
      • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
      询问修复机器人
      添加评论
    3. Disassembling IBM WorkPad c3 Front Case: 步骤 6 中的图像 1,2 Disassembling IBM WorkPad c3 Front Case: 步骤 6 中的图像 2,2
      • The device will be extremely hot. Use a towel or oven mitt to grab it.
      • Using the Plastic Opening Tools, take the front of the case off.
      • If the case is difficult to remove, try repeating step 2.
      • The power button at the top of the device will be loose once the front part of the case is removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G35
3 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 42
总计 2,990
