跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM WorkPad c3 Back Case
你所需要的
    1. Disassembling IBM WorkPad c3 Back Case, Back Case: 步骤 1 中的图像 1,2 Disassembling IBM WorkPad c3 Back Case, Back Case: 步骤 1 中的图像 2,2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      询问修复机器人
      添加评论
    2. Disassembling IBM WorkPad c3 Back Case: 步骤 2 中的图像 1,1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      询问修复机器人
      添加评论
    3. Disassembling IBM WorkPad c3 Back Case: 步骤 3 中的图像 1,2 Disassembling IBM WorkPad c3 Back Case: 步骤 3 中的图像 2,2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G35
3 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 77
总计 1,975
