跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM ThinkPad A30 Upper Case
你所需要的
    1. Disassembling IBM ThinkPad A30 Upper Case, Battery: 步骤 1 中的图像 1,2 Disassembling IBM ThinkPad A30 Upper Case, Battery: 步骤 1 中的图像 2,2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      询问修复机器人
      添加评论
    1. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: 步骤 2 中的图像 1,3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: 步骤 2 中的图像 2,3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: 步骤 2 中的图像 3,3
      • Remove the highlighted screw with a Phillips #1 screwdriver.
      • Pull the hard drive out.
      询问修复机器人
      添加评论
    1. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: 步骤 3 中的图像 1,1
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
      询问修复机器人
      添加评论
    2. Disassembling IBM ThinkPad A30 Upper Case: 步骤 4 中的图像 1,1
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Disassembling IBM ThinkPad A30 Upper Case: 步骤 5 中的图像 1,2 Disassembling IBM ThinkPad A30 Upper Case: 步骤 5 中的图像 2,2
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
      询问修复机器人
      添加评论
    4. Disassembling IBM ThinkPad A30 Upper Case: 步骤 6 中的图像 1,3 Disassembling IBM ThinkPad A30 Upper Case: 步骤 6 中的图像 2,3 Disassembling IBM ThinkPad A30 Upper Case: 步骤 6 中的图像 3,3
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
      询问修复机器人
      添加评论
    5. Disassembling IBM ThinkPad A30 Upper Case: 步骤 7 中的图像 1,3 Disassembling IBM ThinkPad A30 Upper Case: 步骤 7 中的图像 2,3 Disassembling IBM ThinkPad A30 Upper Case: 步骤 7 中的图像 3,3
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
      询问修复机器人
      添加评论
    6. Disassembling IBM ThinkPad A30 Upper Case: 步骤 8 中的图像 1,2 Disassembling IBM ThinkPad A30 Upper Case: 步骤 8 中的图像 2,2
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
      询问修复机器人
      添加评论
    7. Disassembling IBM ThinkPad A30 Upper Case: 步骤 9 中的图像 1,3 Disassembling IBM ThinkPad A30 Upper Case: 步骤 9 中的图像 2,3 Disassembling IBM ThinkPad A30 Upper Case: 步骤 9 中的图像 3,3
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alan
于10/07/10注册
380 声望
创作了6篇指南
团队
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G44
4 名成员
创作了90篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 2,645
