跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM ThinkPad A30 Speakers
你所需要的
    1. Disassembling IBM ThinkPad A30 Speakers, Battery: 步骤 1 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers, Battery: 步骤 1 中的图像 2,2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      询问修复机器人
      添加评论
    1. Disassembling IBM ThinkPad A30 Speakers, Upper Case: 步骤 2 中的图像 1,1
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
      询问修复机器人
      添加评论
    2. Disassembling IBM ThinkPad A30 Speakers: 步骤 3 中的图像 1,1
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Disassembling IBM ThinkPad A30 Speakers: 步骤 4 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 4 中的图像 2,2
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
      询问修复机器人
      添加评论
    4. Disassembling IBM ThinkPad A30 Speakers: 步骤 5 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 5 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 5 中的图像 3,3
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
      询问修复机器人
      添加评论
    5. Disassembling IBM ThinkPad A30 Speakers: 步骤 6 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 6 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 6 中的图像 3,3
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
      询问修复机器人
      添加评论
    6. Disassembling IBM ThinkPad A30 Speakers: 步骤 7 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 7 中的图像 2,2
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
      询问修复机器人
      添加评论
    7. Disassembling IBM ThinkPad A30 Speakers: 步骤 8 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 8 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 8 中的图像 3,3
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
      询问修复机器人
      添加评论
    1. Disassembling IBM ThinkPad A30 Speakers, Display Assembly: 步骤 9 中的图像 1,1
      • Remove the 5.6mm screw that holds the LCD to the upper case.
      询问修复机器人
      添加评论
    2. Disassembling IBM ThinkPad A30 Speakers: 步骤 10 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 10 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 10 中的图像 3,3
      • Remove the 5.6mm screw on the left side of the three-pronged connector.
      • Remove the other two 16.7mm screws.
      • Lift and remove connector.
      询问修复机器人
      添加评论
    3. Disassembling IBM ThinkPad A30 Speakers: 步骤 11 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 11 中的图像 2,2
      • Pull out the white tab connecting the LCD to the motherboard.
      询问修复机器人
      添加评论
    4. Disassembling IBM ThinkPad A30 Speakers: 步骤 12 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 12 中的图像 2,2
      • Turn the laptop so that the back is facing you.
      • Remove the four 5.6mm long screws.
      询问修复机器人
      添加评论
    5. Disassembling IBM ThinkPad A30 Speakers: 步骤 13 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 13 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 13 中的图像 3,3
      • Place the laptop so that the LCD is facing you again.
      • Gently lift the LCD monitor up and out.
      • Remove the black plastic tab.
      询问修复机器人
      添加评论
    1. Disassembling IBM ThinkPad A30 Speakers, Fan: 步骤 14 中的图像 1,1
      • Remove the following screws from the fan retention bracket:
      • Single 5.6 mm screw.
      • Three 16.1 mm screws.
      询问修复机器人
      添加评论
    2. Disassembling IBM ThinkPad A30 Speakers: 步骤 15 中的图像 1,1
      • Lift the heatsink bracket up.
      询问修复机器人
      添加评论
    3. Disassembling IBM ThinkPad A30 Speakers: 步骤 16 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 16 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 16 中的图像 3,3
      • Be careful not to pull too hard. There is a cable attached to the fan.
      • Lift the fan/heatsink assembly up.
      • Locate the fan power cable and pull upwards near the connector.
      • Remove the fan/heatsink assembly.
      询问修复机器人
      添加评论
    1. Disassembling IBM ThinkPad A30 Speakers, Speakers: 步骤 17 中的图像 1,1
      • Locate the floppy drive bay.
      • Remove the four 5.6mm screws.
      • Remove the 16mm screw.
      询问修复机器人
      添加评论
    2. Disassembling IBM ThinkPad A30 Speakers: 步骤 18 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 18 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 18 中的图像 3,3
      • Turn the laptop over so the battery is facing you.
      • Locate the modem and ethernet card bay.
      • Remove the two 5.3mm cover screws.
      • Gently lift the cover.
      询问修复机器人
      添加评论
    3. Disassembling IBM ThinkPad A30 Speakers: 步骤 19 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 19 中的图像 2,2
      • Remove the four 9.1mm screws attached to the modem and ethernet cards.
      • When lifting the cards, be careful not to rip out the cables!
      • Gently lift the modem and ethernet cards.
      询问修复机器人
      添加评论
    4. Disassembling IBM ThinkPad A30 Speakers: 步骤 20 中的图像 1,1
      • Locate the hard drive slot.
      • Remove the 8.8mm screw with a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    5. Disassembling IBM ThinkPad A30 Speakers: 步骤 21 中的图像 1,1
      • Turn the laptop over again and orient it as shown.
      • Lift the left side of the floppy disk bay and and pull it out.
      • The black lever will pop out.
      询问修复机器人
      添加评论
    6. Disassembling IBM ThinkPad A30 Speakers: 步骤 22 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 22 中的图像 2,2
      • Locate the CD Drive Bay
      • Remove the three 5.6mm screws.
      • Lift the right side and pull the CD drive bay out.
      询问修复机器人
      添加评论
    7. Disassembling IBM ThinkPad A30 Speakers: 步骤 23 中的图像 1,1
      • Locate the speakers on the bottom left and right of the ThinkPad A30.
      询问修复机器人
      添加评论
    8. Disassembling IBM ThinkPad A30 Speakers: 步骤 24 中的图像 1,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 24 中的图像 2,3 Disassembling IBM ThinkPad A30 Speakers: 步骤 24 中的图像 3,3
      • Remove the 5.6mm screws on each speaker.
      • Pull the right speaker out, making sure there is still slack in the wire.
      询问修复机器人
      添加评论
    9. Disassembling IBM ThinkPad A30 Speakers: 步骤 25 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 25 中的图像 2,2
      • Pull the blue tab that holds the speaker chip and pull the chip out.
      询问修复机器人
      添加评论
    10. Disassembling IBM ThinkPad A30 Speakers: 步骤 26 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 26 中的图像 2,2
      • Remove the wires from the white tabs by lifting the black wire casing.
      询问修复机器人
      添加评论
    11. Disassembling IBM ThinkPad A30 Speakers: 步骤 27 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 27 中的图像 2,2
      • Lift the left speaker out.
      询问修复机器人
      添加评论
    12. Disassembling IBM ThinkPad A30 Speakers: 步骤 28 中的图像 1,2 Disassembling IBM ThinkPad A30 Speakers: 步骤 28 中的图像 2,2
      • Remove the speaker data and power cables by pulling them from the motherboard.
      • You have successfully removed the ThinkPad A30 speakers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alan
于10/07/10注册
380 声望
创作了6篇指南
团队
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G44
4 名成员
创作了77篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 52
总计 2,699
