跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM ThinkPad A30 Motherboard
你所需要的
  1. Disassembling IBM ThinkPad A30 Motherboard, Battery: 步骤 1 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard, Battery: 步骤 1 中的图像 2,2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    询问修复机器人
    添加评论
  2. Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: 步骤 2 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: 步骤 2 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: 步骤 2 中的图像 3,3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
    询问修复机器人
    添加评论
  3. Disassembling IBM ThinkPad A30 Motherboard, CD Drive: 步骤 3 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard, CD Drive: 步骤 3 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard, CD Drive: 步骤 3 中的图像 3,3
    • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
    • Slide the switch to the right. A black plastic tab will pop out.
    • Pull the plastic tab to expose the CD drive.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
    询问修复机器人
    添加评论
  4. Disassembling IBM ThinkPad A30 Motherboard: 步骤 4 中的图像 1,1
    • Carefully pull the CD drive out from the laptop.
    询问修复机器人
    添加评论
  5. Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: 步骤 5 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: 步骤 5 中的图像 2,2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    询问修复机器人
    添加评论
  6. Disassembling IBM ThinkPad A30 Motherboard: 步骤 6 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 6 中的图像 2,2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    询问修复机器人
    添加评论
  7. Disassembling IBM ThinkPad A30 Motherboard, Upper Case: 步骤 7 中的图像 1,1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    询问修复机器人
    添加评论
  8. Disassembling IBM ThinkPad A30 Motherboard: 步骤 8 中的图像 1,1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  9. Disassembling IBM ThinkPad A30 Motherboard: 步骤 9 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 9 中的图像 2,2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    询问修复机器人
    添加评论
  10. Disassembling IBM ThinkPad A30 Motherboard: 步骤 10 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 10 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 10 中的图像 3,3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    询问修复机器人
    添加评论
  11. Disassembling IBM ThinkPad A30 Motherboard: 步骤 11 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 11 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 11 中的图像 3,3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    询问修复机器人
    添加评论
  12. Disassembling IBM ThinkPad A30 Motherboard: 步骤 12 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 12 中的图像 2,2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    询问修复机器人
    添加评论
  13. Disassembling IBM ThinkPad A30 Motherboard: 步骤 13 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 13 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 13 中的图像 3,3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    询问修复机器人
    添加评论
  14. Disassembling IBM ThinkPad A30 Motherboard, Display Assembly: 步骤 14 中的图像 1,1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    询问修复机器人
    添加评论
  15. Disassembling IBM ThinkPad A30 Motherboard: 步骤 15 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 15 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 15 中的图像 3,3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    询问修复机器人
    添加评论
  16. Disassembling IBM ThinkPad A30 Motherboard: 步骤 16 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 16 中的图像 2,2
    • Pull out the white tab connecting the LCD to the motherboard.
    询问修复机器人
    添加评论
  17. Disassembling IBM ThinkPad A30 Motherboard: 步骤 17 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 17 中的图像 2,2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    询问修复机器人
    添加评论
  18. Disassembling IBM ThinkPad A30 Motherboard: 步骤 18 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 18 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 18 中的图像 3,3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    询问修复机器人
    添加评论
  19. Disassembling IBM ThinkPad A30 Motherboard, Fan: 步骤 19 中的图像 1,1
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    询问修复机器人
    添加评论
  20. Disassembling IBM ThinkPad A30 Motherboard: 步骤 20 中的图像 1,1
    • Lift the heatsink bracket up.
    询问修复机器人
    添加评论
  21. Disassembling IBM ThinkPad A30 Motherboard: 步骤 21 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 21 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 21 中的图像 3,3
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    询问修复机器人
    添加评论
  22. Disassembling IBM ThinkPad A30 Motherboard, CPU: 步骤 22 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard, CPU: 步骤 22 中的图像 2,2
    • Use a flathead to turn the screw 180 degrees.
    • Remove the CPU by lifting it upwards.
    • If the CPU is reusable, place it in an antistatic bag and away from moisture.
    询问修复机器人
    添加评论
  23. Disassembling IBM ThinkPad A30 Motherboard, Motherboard: 步骤 23 中的图像 1,1
    • Locate the floppy drive bay.
    • Remove the four 5.6mm screws.
    • Remove the 16mm screw.
    询问修复机器人
    添加评论
  24. Disassembling IBM ThinkPad A30 Motherboard: 步骤 24 中的图像 1,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 24 中的图像 2,3 Disassembling IBM ThinkPad A30 Motherboard: 步骤 24 中的图像 3,3
    • Turn the laptop over so that the battery is towards you.
    • Locate the modem and ethernet card bay.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
    询问修复机器人
    添加评论
  25. Disassembling IBM ThinkPad A30 Motherboard: 步骤 25 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 25 中的图像 2,2
    • Remove the four 9.1mm screws attached to the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    询问修复机器人
    添加评论
  26. Disassembling IBM ThinkPad A30 Motherboard: 步骤 26 中的图像 1,1
    • Locate the hard drive slot.
    • Remove the 8.8mm screw with a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  27. Disassembling IBM ThinkPad A30 Motherboard: 步骤 27 中的图像 1,1
    • Turn the laptop over again and orient it as shown.
    • Lift the left side of the floppy disk bay and and pull it out.
    • The black lever will pop out.
    询问修复机器人
    添加评论
  28. Disassembling IBM ThinkPad A30 Motherboard: 步骤 28 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 28 中的图像 2,2
    • Locate the CD Drive Bay
    • Remove the three 5.6mm screws.
    • Lift the right side and pull the CD drive bay out.
    询问修复机器人
    添加评论
  29. Disassembling IBM ThinkPad A30 Motherboard: 步骤 29 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 29 中的图像 2,2
    • Once the CD drive bay is removed, locate the speaker data and power cables.
    • Remove the cables from the motherboard.
    询问修复机器人
    添加评论
  30. Disassembling IBM ThinkPad A30 Motherboard: 步骤 30 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 30 中的图像 2,2
    • Locate the expansion bay.
    • Lift and remove the expansion bay.
    询问修复机器人
    添加评论
  31. Disassembling IBM ThinkPad A30 Motherboard: 步骤 31 中的图像 1,1
    • Rotate the laptop so that the back ports are facing you.
    询问修复机器人
    添加评论
  32. Disassembling IBM ThinkPad A30 Motherboard: 步骤 32 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 32 中的图像 2,2
    • Remove the three 5.8mm screws with a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  33. Disassembling IBM ThinkPad A30 Motherboard: 步骤 33 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 33 中的图像 2,2
    • Remove the six 11mm nuts with a wrench.
    • Pliers can be used, but are not recommended.
    询问修复机器人
    添加评论
  34. Disassembling IBM ThinkPad A30 Motherboard: 步骤 34 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 34 中的图像 2,2
    • Rotate the laptop to its original position.
    • Remove the 5.6mm screw located on the upper right corner of the motherboard.
    询问修复机器人
    添加评论
  35. Disassembling IBM ThinkPad A30 Motherboard: 步骤 35 中的图像 1,2 Disassembling IBM ThinkPad A30 Motherboard: 步骤 35 中的图像 2,2
    • The wireless and bluetooth cards are connected to the motherboard!
    • Pull out the motherboard towards you carefully.
    • Place the motherboard somewhere dry and clean.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Alan
于10/07/10注册
380 声望
创作了6篇指南
团队
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G44
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 39
总计 9,084
