跳转到主内容
加入维修社区 - 创建账户
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: 步骤 1 中的图像 1,2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: 步骤 1 中的图像 2,2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    询问修复机器人
    添加评论
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: 步骤 2 中的图像 1,2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: 步骤 2 中的图像 2,2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    询问修复机器人
    添加评论
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: 步骤 3 中的图像 1,2 Disassembling IBM ThinkPad A30 Floppy Disk Drive: 步骤 3 中的图像 2,2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    询问修复机器人
    添加评论
结论
To reassemble, place the floppy disk drive back into its bay the way it was facing before
取消:我没有完成这个指南。
Jessica
于10/06/10注册
162 声望
创作了7篇指南
团队
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G44
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 43
总计 3,218
