跳转到主内容
加入维修社区 - 创建账户
Disassembling Flip Video USB Port
你所需要的
  1. Disassembling Flip Video USB Port, Outer Shell: 步骤 1 中的图像 1,2 Disassembling Flip Video USB Port, Outer Shell: 步骤 1 中的图像 2,2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
    询问修复机器人
    添加评论
  2. Disassembling Flip Video USB Port: 步骤 2 中的图像 1,1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    询问修复机器人
    添加评论
  3. Disassembling Flip Video USB Port: 步骤 3 中的图像 1,2 Disassembling Flip Video USB Port: 步骤 3 中的图像 2,2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    询问修复机器人
    添加评论
  4. Disassembling Flip Video USB Port: 步骤 4 中的图像 1,1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
    询问修复机器人
    添加评论
  5. Disassembling Flip Video USB Port: 步骤 5 中的图像 1,1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
    询问修复机器人
    添加评论
  6. Disassembling Flip Video USB Port, Circuit Board: 步骤 6 中的图像 1,1
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    询问修复机器人
    添加评论
  7. Disassembling Flip Video USB Port: 步骤 7 中的图像 1,1
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
    询问修复机器人
    添加评论
  8. Disassembling Flip Video USB Port: 步骤 8 中的图像 1,1
    • Disconnect the USB port cable from the back side of the circuit board.
    询问修复机器人
    添加评论
  9. Disassembling Flip Video USB Port: 步骤 9 中的图像 1,1
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
    询问修复机器人
    添加评论
  10. Disassembling Flip Video USB Port, USB Port: 步骤 10 中的图像 1,1
    • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
    询问修复机器人
    添加评论
  11. Disassembling Flip Video USB Port: 步骤 11 中的图像 1,1
    • Lift wire out of the outer shell slot.
    • The wire mount should stay attached to the wire.
    询问修复机器人
    添加评论
  12. Disassembling Flip Video USB Port: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove the spring that holds the port door shut.
    • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
    询问修复机器人
    添加评论
  13. Disassembling Flip Video USB Port: 步骤 13 中的图像 1,1
    • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
    询问修复机器人
    添加评论
  14. Disassembling Flip Video USB Port: 步骤 14 中的图像 1,1
    • Remove the USB port cover.
    询问修复机器人
    添加评论
  15. Disassembling Flip Video USB Port: 步骤 15 中的图像 1,1
    • Remove the USB slider.
    询问修复机器人
    添加评论
  16. Disassembling Flip Video USB Port: 步骤 16 中的图像 1,1
    • Lift out the USB port slowly.
    • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Elizabeth
于04/15/10注册
100 声望
创作了6篇指南
团队
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G21
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 22
总计 4,497
