跳转到主内容
加入维修社区 - 创建账户
Disassembling Epson PPC650 Replacing Flash
你所需要的
  1. Disassembling Epson PPC650 Replacing Flash, Case: 步骤 1 中的图像 1,3 Disassembling Epson PPC650 Replacing Flash, Case: 步骤 1 中的图像 2,3 Disassembling Epson PPC650 Replacing Flash, Case: 步骤 1 中的图像 3,3
    • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
    • Remove the batteries from the battery compartment located on the underside of the camera.
    • Remove the SD card from the compartment located on the flat, left side of the camera.
    询问修复机器人
    添加评论
  2. Disassembling Epson PPC650 Replacing Flash: 步骤 2 中的图像 1,1
    • Remove the two screws on the rounded side of the camera.
    询问修复机器人
    添加评论
  3. Disassembling Epson PPC650 Replacing Flash: 步骤 3 中的图像 1,2 Disassembling Epson PPC650 Replacing Flash: 步骤 3 中的图像 2,2
    • Remove the three screws on the flat side of the camera.
    • All of the silver screws go into the side of the camera that is silver.
    • All of the black screws go into the side of the camera that is black.
    询问修复机器人
    添加评论
  4. Disassembling Epson PPC650 Replacing Flash: 步骤 4 中的图像 1,1
    • Remove the four screws from the bottom of the camera.
    询问修复机器人
    添加评论
  5. Disassembling Epson PPC650 Replacing Flash: 步骤 5 中的图像 1,3 Disassembling Epson PPC650 Replacing Flash: 步骤 5 中的图像 2,3 Disassembling Epson PPC650 Replacing Flash: 步骤 5 中的图像 3,3
    • Separate the front and the back pieces of the camera's plastic casing using a spudger.
    • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
    • Use minimal force so that the plastic casing does not break.
    • When separating the small silver siding, the indicator for the view/off/playback may fall out.
    • The plastic viewing window located on the top of the camera may also become lose and fall out.
    询问修复机器人
    添加评论
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 步骤 6 中的图像 1,3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 步骤 6 中的图像 2,3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 步骤 6 中的图像 3,3
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
    询问修复机器人
    添加评论
  7. Disassembling Epson PPC650 Replacing Flash: 步骤 7 中的图像 1,1
    • Remove clear rubber band holding flash in line with wiring.
    询问修复机器人
    添加评论
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    询问修复机器人
    添加评论
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Xan Danes
于02/14/13注册
134 声望
撰写一个指南
团队
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 的会员
OSU-BUEHL-S13S1G5
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 30
总计 635
