跳转到主内容
加入维修社区 - 创建账户
Disassembling Chef's Choice M115 Case
你所需要的
    1. Disassembling Chef's Choice M115 Case, Case: 步骤 1 中的图像 1,2 Disassembling Chef's Choice M115 Case, Case: 步骤 1 中的图像 2,2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      询问修复机器人
      添加评论
    2. Disassembling Chef's Choice M115 Case: 步骤 2 中的图像 1,1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      询问修复机器人
      添加评论
    3. Disassembling Chef's Choice M115 Case: 步骤 3 中的图像 1,1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      询问修复机器人
      添加评论
    4. Disassembling Chef's Choice M115 Case: 步骤 4 中的图像 1,1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G3
5 名成员
创作了33篇指南
2指南评论
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - 回复 分享
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 71
总计 2,496
