跳转到主内容
加入维修社区 - 创建账户
Disassembling Canon PowerShot SD700 Lens
你所需要的
    1. Disassembling Canon PowerShot SD700 Lens, Outside Case: 步骤 1 中的图像 1,1
      • Turn off the camera by pressing the power button above the LCD screen.
      询问修复机器人
      添加评论
    2. Disassembling Canon PowerShot SD700 Lens: 步骤 2 中的图像 1,1
      • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Disassembling Canon PowerShot SD700 Lens: 步骤 3 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
      询问修复机器人
      添加评论
    4. Disassembling Canon PowerShot SD700 Lens: 步骤 4 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
      询问修复机器人
      添加评论
    5. Disassembling Canon PowerShot SD700 Lens: 步骤 5 中的图像 1,1
      • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
      • This screw will be longer than the rest of the screws.
      询问修复机器人
      添加评论
    6. Disassembling Canon PowerShot SD700 Lens: 步骤 6 中的图像 1,1
      • Remove the front, back, and side casings from the camera and set to the side.
      询问修复机器人
      添加评论
    1. Disassembling Canon PowerShot SD700 Lens, LCD screen: 步骤 7 中的图像 1,1
      • Remove the two screws that connect the LCD and backlight to the main body of the camera.
      询问修复机器人
      添加评论
    2. Disassembling Canon PowerShot SD700 Lens: 步骤 8 中的图像 1,3 Disassembling Canon PowerShot SD700 Lens: 步骤 8 中的图像 2,3 Disassembling Canon PowerShot SD700 Lens: 步骤 8 中的图像 3,3
      • Gently pry the LCD and the backlight from the main body of the camera.
      • Gently pry the LCD from the backlight.
      • The thin ribbon cable is for the backlight.
      • The thick ribbon cable is for the LCD screen.
      询问修复机器人
      添加评论
    3. Disassembling Canon PowerShot SD700 Lens: 步骤 9 中的图像 1,1
      • Carefully lift the ZIF connector that covers the thick ribbon cable.
      • This ZIF connector is fragile. Use caution when lifting it from its down position.
      • Insert the new LCD and reassemble the camera.
      添加评论
    1. Disassembling Canon PowerShot SD700 Lens, Backlight: 步骤 10 中的图像 1,1
      在这个步骤中使用的工具:
      • Unplug the ribbon from the housing on the circuitry.
      • Take the new ribbon and insert it into the housing.
      • Tweezers or a tool with a sharp point can be used.
      询问修复机器人
      添加评论
    1. Disassembling Canon PowerShot SD700 Lens, Motherboard: 步骤 11 中的图像 1,1
      • Detach the LCD and backlight.
      • Remove the larger screw.
      • Remove the two smaller sized screws.
      • Remove the small screw.
      添加评论
    2. Disassembling Canon PowerShot SD700 Lens: 步骤 12 中的图像 1,1
      • Remove the two screws near the the tripod mount using a Phillips #00 screwdriver.
      添加评论
    3. Disassembling Canon PowerShot SD700 Lens: 步骤 13 中的图像 1,1
      • Remove the screw next to the shutter on the top of the camera with a Phillips screwdriver.
      询问修复机器人
      添加评论
    4. Disassembling Canon PowerShot SD700 Lens: 步骤 14 中的图像 1,1
      • Remove the orange ribbon cable by lifting the ZIF connector attached to the ribbon with a spudger.
      添加评论
    5. Disassembling Canon PowerShot SD700 Lens: 步骤 15 中的图像 1,2 Disassembling Canon PowerShot SD700 Lens: 步骤 15 中的图像 2,2
      • Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard.
      询问修复机器人
      添加评论
    6. Disassembling Canon PowerShot SD700 Lens: 步骤 16 中的图像 1,3 Disassembling Canon PowerShot SD700 Lens: 步骤 16 中的图像 2,3 Disassembling Canon PowerShot SD700 Lens: 步骤 16 中的图像 3,3
      • With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
      询问修复机器人
      添加评论
    7. Disassembling Canon PowerShot SD700 Lens: 步骤 17 中的图像 1,2 Disassembling Canon PowerShot SD700 Lens: 步骤 17 中的图像 2,2
      • Disconnect the wires that are attached to the motherboard.
      • Remove the film by lifting it gently from the motherboard.
      询问修复机器人
      添加评论
    8. Disassembling Canon PowerShot SD700 Lens: 步骤 18 中的图像 1,1
      • Remove the last wires connected to the motherboard by gently lifting upwards.
      询问修复机器人
      添加评论
    9. Disassembling Canon PowerShot SD700 Lens: 步骤 19 中的图像 1,2 Disassembling Canon PowerShot SD700 Lens: 步骤 19 中的图像 2,2
      • Use a spudger to gently lift the circuit board.
      询问修复机器人
      添加评论
    10. Disassembling Canon PowerShot SD700 Lens: 步骤 20 中的图像 1,2 Disassembling Canon PowerShot SD700 Lens: 步骤 20 中的图像 2,2
      • Remove the screw using a Phillips #00 screwdriver.
      • Gently lift the motherboard away from the case.
      询问修复机器人
      添加评论
    11. Disassembling Canon PowerShot SD700 Lens: 步骤 21 中的图像 1,2 Disassembling Canon PowerShot SD700 Lens: 步骤 21 中的图像 2,2
      • Remove the screw.
      • Once the screw is removed, you can remove the board.
      询问修复机器人
      添加评论
    1. Disassembling Canon PowerShot SD700 Lens, Lens: 步骤 22 中的图像 1,1
      • Once you have removed the lens from the main chassis, gently brush off any dirt, sand, or dust that may have accumulated in the crevices. Using a compressed air canister or a brush can help remove all the dirt.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Aaron Lee
于04/07/11注册
212 声望
创作了3篇指南
团队
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 的会员
CPSU-WALTERS-S11S9G71
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 55
总计 5,607
