跳转到主内容
加入维修社区 - 创建账户
Disassembling Apple IIc Cover
你所需要的
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: 步骤 1 中的图像 1,2 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: 步骤 1 中的图像 2,2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    询问修复机器人
    添加评论
  2. Disassembling Apple IIc Cover: 步骤 2 中的图像 1,2 Disassembling Apple IIc Cover: 步骤 2 中的图像 2,2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    询问修复机器人
    添加评论
  3. Disassembling Apple IIc Cover: 步骤 3 中的图像 1,2 Disassembling Apple IIc Cover: 步骤 3 中的图像 2,2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    添加评论
  4. Disassembling Apple IIc Cover: 步骤 4 中的图像 1,2 Disassembling Apple IIc Cover: 步骤 4 中的图像 2,2
    • Lift the handle straight up to remove.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
团队
Cal Poly, Team 21-23, Maness Fall 2011 Cal Poly, Team 21-23, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G23
4 名成员
创作了14篇指南
3指南评论
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - 回复 分享
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III - 回复 分享
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 79
总计 11,357
