跳转到主内容
加入维修社区 - 创建账户
Disassembling Antsle One D Server
你所需要的
    1. Disassembling Antsle One D Server, Remove Front Plate: 步骤 1 中的图像 1,3 Disassembling Antsle One D Server, Remove Front Plate: 步骤 1 中的图像 2,3 Disassembling Antsle One D Server, Remove Front Plate: 步骤 1 中的图像 3,3
      • Remove the screws from the front panel.
      • There are also two screws in the front bottom of the plate that need to be removed.
      • When pulling the plate away from the body, be careful as a spring is keeping the silver button in place. The spring also easily slips off the button. Keep an eye out so you don't lose either of these items.
      询问修复机器人
      添加评论
    2. Disassembling Antsle One D Server, Remove bottom plate: 步骤 2 中的图像 1,2 Disassembling Antsle One D Server, Remove bottom plate: 步骤 2 中的图像 2,2
      • To remove the bottom plate, remove the four-foot screws and the two screws from the rear plate, and the bottom will slide out.
      询问修复机器人
      添加评论
    3. Disassembling Antsle One D Server, Remove Back Plate: 步骤 3 中的图像 1,1
      • Remove the four screws from the rear plate
      • Unscrew the DC input connector
      • After, completing the previous step, and these six screws are removed, you can safely detach the rear plate.
      询问修复机器人
      添加评论
    4. Disassembling Antsle One D Server, Remove Front Panel PCB: 步骤 4 中的图像 1,1
      • Remove the two screws keeping the PCB mounted
      • Disconnect the power cable.
      询问修复机器人
      添加评论
    5. Disassembling Antsle One D Server, Remove the hard drive bay: 步骤 5 中的图像 1,2 Disassembling Antsle One D Server, Remove the hard drive bay: 步骤 5 中的图像 2,2
      • Disconnect the power and SATA cables from the hard drives.
      • Remove the four screws keeping the hard drives in place.
      询问修复机器人
      添加评论
    6. Disassembling Antsle One D Server, Remove the motherboard: 步骤 6 中的图像 1,2 Disassembling Antsle One D Server, Remove the motherboard: 步骤 6 中的图像 2,2
      • Remove the four internal screws keeping the CPU pressed against the heat sink (labeled orange).
      • Remove the four outer screws (labeled yellow).
      • Lift the motherboard away. The thermal paste may have good adhesion and additional gentle force may be needed to pry it away.
      询问修复机器人
      添加评论
      • Out of the box, the Antsle One D comes with 2 SATA hard drives. These can be disconnected from the SATA ports.
      • The front panel PCB is connected via a <look up> wire.
      • A power connector goes from the DC input to the motherboard.
      • A <look up> connector goes from the motherboard to the hard drive bay.
      询问修复机器人
      添加评论
    7. Disassembling Antsle One D Server, CPU & RAM: 步骤 8 中的图像 1,2 Disassembling Antsle One D Server, CPU & RAM: 步骤 8 中的图像 2,2
      • CPU - Intel C3558 SR388 2.20GHZ
      • RAM - DDR4 2666 RDIMM 1.2v CL19
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
fausty
于06/16/24注册
725 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 376
