跳转到主内容
加入维修社区 - 创建账户
Disassembling Ableton Move Backplate
  1. Disassembling Ableton Move Backplate, Remove visible screws: 步骤 1 中的图像 1,1
    • First unscrew the 4 accessible screws on the bottom of the unit
    询问修复机器人
    添加评论
  2. Disassembling Ableton Move Backplate, Remove hidden screws: 步骤 2 中的图像 1,1
    • There are 4 more screws here. To access them, you need peel off the rubber pads. If you are careful, you can get away with not peeling them off completely. In this image, the purple areas mark the areas that I found relatively "safe" to peel off to be able to get access to the screws but also allowed to gently push the pads back on.
    询问修复机器人
    添加评论
  3. Disassembling Ableton Move Backplate, That's it.: 步骤 3 中的图像 1,1
    • After removing the screws under the rubber pads, the backplate should gently fall off under it's own weight. If not, help a little with plastic opening tools.
    • Now you have access to the SD card, the raspberry pi 4 compute module, the Intel WiFi Chip, the battery, and the builtin 8 Ohm 2W speakers.
    • Taking apart the unit further than this holds the risk of damaging it significantly, so only progress with lots of caution.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
losferatu
于10/30/24注册
194 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 57
总计 538
