跳转到主内容
加入维修社区 - 创建账户
Disassembling APEX AP-GS918 Screen
你所需要的
  1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: 步骤 1 中的图像 1,3 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 步骤 1 中的图像 2,3 Disassembling APEX AP-GS918 Screen, Power/Volume Button: 步骤 1 中的图像 3,3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    询问修复机器人
    添加评论
  2. Disassembling APEX AP-GS918 Screen: 步骤 2 中的图像 1,3 Disassembling APEX AP-GS918 Screen: 步骤 2 中的图像 2,3 Disassembling APEX AP-GS918 Screen: 步骤 2 中的图像 3,3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    询问修复机器人
    添加评论
  3. Disassembling APEX AP-GS918 Screen: 步骤 3 中的图像 1,2 Disassembling APEX AP-GS918 Screen: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    询问修复机器人
    添加评论
  4. Disassembling APEX AP-GS918 Screen, Battery: 步骤 4 中的图像 1,2 Disassembling APEX AP-GS918 Screen, Battery: 步骤 4 中的图像 2,2
    • Begin removing the black tape covering the motherboard inside the tablet.
    询问修复机器人
    添加评论
  5. Disassembling APEX AP-GS918 Screen: 步骤 5 中的图像 1,1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    询问修复机器人
    添加评论
  6. Disassembling APEX AP-GS918 Screen: 步骤 6 中的图像 1,2 Disassembling APEX AP-GS918 Screen: 步骤 6 中的图像 2,2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
    询问修复机器人
    添加评论
  7. Disassembling APEX AP-GS918 Screen, Screen: 步骤 7 中的图像 1,2 Disassembling APEX AP-GS918 Screen, Screen: 步骤 7 中的图像 2,2
    • The motherboard will need to be removed in order to access the screen.
    • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
    询问修复机器人
    添加评论
  8. Disassembling APEX AP-GS918 Screen: 步骤 8 中的图像 1,2 Disassembling APEX AP-GS918 Screen: 步骤 8 中的图像 2,2
    • To finish removing the motherboard you must release the two data cables holding the screen to it.
    • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
    • You can now remove the data cables from the slots and lift the motherboard out from the device.
    询问修复机器人
    添加评论
  9. Disassembling APEX AP-GS918 Screen: 步骤 9 中的图像 1,2 Disassembling APEX AP-GS918 Screen: 步骤 9 中的图像 2,2
    • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
    询问修复机器人
    添加评论
  10. Disassembling APEX AP-GS918 Screen: 步骤 10 中的图像 1,1
    • Pull the thin plastic screen casing apart and you can remove the damaged screen.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G1
3 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 45
总计 944
