跳转到主内容
加入维修社区 - 创建账户
Disassembling & Cleaning the Brewgroup
你所需要的
  1. Disassembling & Cleaning the Brewgroup, disassembly & cleaning the brewing unit: 步骤 1 中的图像 1,3 Disassembling & Cleaning the Brewgroup, disassembly & cleaning the brewing unit: 步骤 1 中的图像 2,3 Disassembling & Cleaning the Brewgroup, disassembly & cleaning the brewing unit: 步骤 1 中的图像 3,3
    • Remove the the brewgroup from the machine by simultaneously pressing the "Push" bar and pulling towards you.
    • Using your phillips screwdriver, remove the two screws holding the grey bracket and white hose in place.
    询问修复机器人
    添加评论
  2. Disassembling & Cleaning the Brewgroup: 步骤 2 中的图像 1,1
    • Remove the retaining bracket.
    询问修复机器人
    添加评论
  3. Disassembling & Cleaning the Brewgroup: 步骤 3 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 3 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 3 中的图像 3,3
    • Remove the two screws holding the valve in place and remove it.
    • It is normally not necessary to open and clean the valve. If you do open it be careful as there are many small parts inside and if reassembled incorrectly coffee will not flow.
    询问修复机器人
    添加评论
  4. Disassembling & Cleaning the Brewgroup: 步骤 4 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 4 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 4 中的图像 3,3
    • The upper piston is held in place by four clips, two on each side. To remove it, place a screwdriver lengthwise across both clips on one side, and depress them while pushing down on the top of piston. That should loosen one side, then do the same for the other and the piston assembly should come loose.
    询问修复机器人
    添加评论
  5. Disassembling & Cleaning the Brewgroup: 步骤 5 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 5 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 5 中的图像 3,3
    • Once the piston assembly is out, unscrew and remove the brew screen.
    询问修复机器人
    添加评论
  6. Disassembling & Cleaning the Brewgroup: 步骤 6 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 6 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 6 中的图像 3,3
    • Remove the piston gasket and clean any coffee from the channel it sits in.
    • The top strainer gets a bath in some degreasant. A tooth-brush can penetrate every pore of the strainer. Sometimes can help a tooth-pick. In some cases, a needle will help you too. Rinse with water.
    • Take a look at the strainer, hold it towards the window or some strong light. you should be able to look through every hole. Well done.
    询问修复机器人
    添加评论
  7. Disassembling & Cleaning the Brewgroup: 步骤 7 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 7 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 7 中的图像 3,3
    • Before reassembling, its a good advice for cleaning the rest of the brewgroup with water, brush and some mild degreasant. Then the result will be best.
    询问修复机器人
    添加评论
  8. Disassembling & Cleaning the Brewgroup: 步骤 8 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 8 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 8 中的图像 3,3
    • PLace your nice and clean seal on your nice and clean piston.
    • Then screw in the strainer
    • Smile at your nice work.
    询问修复机器人
    添加评论
  9. Disassembling & Cleaning the Brewgroup: 步骤 9 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 9 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 9 中的图像 3,3
    • The top piston only fits right in one position, so look at the pictures ! In the white circle, you see the connecting for the valve. That part has to face towards the top.
    • On the second picture you see the notches, Both have to glide in the Piston holder.
    • On the third picture you see the clips. All 4 of them have to snap in correctly. No problem.
    询问修复机器人
    添加评论
  10. Disassembling & Cleaning the Brewgroup: 步骤 10 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 10 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 10 中的图像 3,3
    • PLace the valve with the white hose towrds the front of the brewgroup and screw it tight.
    • Then mount the hose holder like shown on the second picture.
    • The last two screws - done.
    询问修复机器人
    添加评论
  11. Disassembling & Cleaning the Brewgroup: 步骤 11 中的图像 1,3 Disassembling & Cleaning the Brewgroup: 步骤 11 中的图像 2,3 Disassembling & Cleaning the Brewgroup: 步骤 11 中的图像 3,3
    • Be sure to check the correct position of the two small arrows on the turning part of the brewgroup. The arrows must exactly face to each other.
    • The gearbox will get destroyed if the brewgroup is pushed with force into the holder in the machine. Never use force, it must glide freely and easy into the holder inside the machine!
    • The first coffee should get poured in the drain because the first coffee will contain traces of the degreasant.
    • The next cup of coffee will be an aesthetic pleasure of aromes, flavor and well formed Crèma. Enjoy.
    询问修复机器人
    添加评论
结论
A simple cleaning can revitalize your espresso machine.
取消:我没有完成这个指南。
9等其他人完成本指南。
Schwarzstein
于07/15/13注册
2,964 声望
创作了13篇指南
1指南评论
El elevador no baja a su posición, como lo regresas a la posición de N, se quedó arriba en el filtro, como lo regresas
Ivan cardenas - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 46
过去 30 天: 179
总计 8,954
