跳转到主内容
Dirt Devil Gator Circuit Board Replacement
你所需要的
  1. Dirt Devil Gator Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Press the button found in the middle of the vacuum downwards. Then, separate the front from the back of the device by gently pulling apart.
  2. Dirt Devil Gator Circuit Board Replacement: 步骤 2 中的图像 1,3 Dirt Devil Gator Circuit Board Replacement: 步骤 2 中的图像 2,3 Dirt Devil Gator Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Separate the front and the back and set the front aside.
    • Pull on the back of the vacuum, there should not be too much resistance when pulling it out.
  3. Dirt Devil Gator Circuit Board Replacement: 步骤 3 中的图像 1,3 Dirt Devil Gator Circuit Board Replacement: 步骤 3 中的图像 2,3 Dirt Devil Gator Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Unscrew each individual 13 mm screws from the vacuum with a micro screwdriver.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
  4. Dirt Devil Gator Circuit Board Replacement: 步骤 4 中的图像 1,3 Dirt Devil Gator Circuit Board Replacement: 步骤 4 中的图像 2,3 Dirt Devil Gator Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Remove the grey switch from the top of the device by pulling gently. Then, remove the complete motor by also pulling gently out of socket.
    • Take note that the circuit is at the top of the vacuum and everything must be removed
  5. Dirt Devil Gator Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Remove the motor from your Dirt Devil Gator exterior by slightly pulling out the white motor.
    • Includes: batteries, motor, circuit board, wires
  6. Dirt Devil Gator Circuit Board Replacement: 步骤 6 中的图像 1,2 Dirt Devil Gator Circuit Board Replacement: 步骤 6 中的图像 2,2
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 466
