跳转到主内容
Dirt Devil Gator Charger Replacement
你所需要的
  1. Dirt Devil Gator Charger Replacement, Charger: 步骤 1 中的图像 1,1
    • Press the button on the middle of the vacuum by pushing down on it and pulling the device apart.
  2. Dirt Devil Gator Charger Replacement: 步骤 2 中的图像 1,3 Dirt Devil Gator Charger Replacement: 步骤 2 中的图像 2,3 Dirt Devil Gator Charger Replacement: 步骤 2 中的图像 3,3
    • Separate the front and back half of the vacuum.
    • Pull on the back of the vacuum, there should not be too much resistance when pulling it out.
  3. Dirt Devil Gator Charger Replacement: 步骤 3 中的图像 1,3 Dirt Devil Gator Charger Replacement: 步骤 3 中的图像 2,3 Dirt Devil Gator Charger Replacement: 步骤 3 中的图像 3,3
    • Unscrew each individual 13 mm screws with a micro screwdriver from the vacuum.
    • After unscrewing all of the screws, firmly pull on the side of the vacuum to separate the exterior.
  4. Dirt Devil Gator Charger Replacement: 步骤 4 中的图像 1,3 Dirt Devil Gator Charger Replacement: 步骤 4 中的图像 2,3 Dirt Devil Gator Charger Replacement: 步骤 4 中的图像 3,3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Charger Replacement: 步骤 5 中的图像 1,1
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 851
