简介
This guide will help users to replace buttons on top of the Digitech XC-5206 speaker system, including: volume controls, power button, and Bluetooth button. Please refer to troubleshooting page before beginning replacement guide steps.
你所需要的
Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
OR grab ahold of the silver tab to pull the speaker face out. This may require force.
