跳转到主内容
加入维修社区 - 创建账户
Digiland DL8006 Battery Replacement
你所需要的
    1. Digiland DL8006 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Digiland DL8006 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Digiland DL8006 Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Place the device down on its front with the back facing upward.
      • Split the two faces of the device with a plastic opening tool to pry the back cover off.
      • Remove the silver/metallic tape covering the bottom end of the tablet.
      询问修复机器人
      添加评论
    2. Digiland DL8006 Battery Replacement: 步骤 2 中的图像 1,3 Digiland DL8006 Battery Replacement: 步骤 2 中的图像 2,3 Digiland DL8006 Battery Replacement: 步骤 2 中的图像 3,3
      • Remove the red & black wire that connects the motherboard to the bottom end of the tablet.
      • Remove the ribbon cable over the battery by flipping up the plastic tab on the ZIF connector on either side of the cable and pulling it out.
      询问修复机器人
      添加评论
    3. Digiland DL8006 Battery Replacement: 步骤 3 中的图像 1,2 Digiland DL8006 Battery Replacement: 步骤 3 中的图像 2,2
      • Remove the red & blue cord connecting the battery to the motherboard.
      • Remove the tape connecting the motherboard to the back of the LED screen.
      • Pry open with a plastic opening tool along the top and bottom edges until the battery is free from the device.
      • Remove all the remaining tape from the battery.
      • It may be helpful to remove the motherboard prior to prying the battery out for better leverage on the edges.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Landon Choi
于10/30/19注册
379 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 627
