跳转到主内容
加入维修社区 - 创建账户
DigiTech RP70 Footswitch Replacement
你所需要的
    1. DigiTech RP70  Footswitch Replacement, Motherboard: 步骤 1 中的图像 1,2 DigiTech RP70  Footswitch Replacement, Motherboard: 步骤 1 中的图像 2,2
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      询问修复机器人
      添加评论
    2. DigiTech RP70  Footswitch Replacement: 步骤 2 中的图像 1,2 DigiTech RP70  Footswitch Replacement: 步骤 2 中的图像 2,2
      • Remove the back panel to expose the motherboard.
      询问修复机器人
      添加评论
    3. DigiTech RP70  Footswitch Replacement: 步骤 3 中的图像 1,1
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      询问修复机器人
      添加评论
    4. DigiTech RP70  Footswitch Replacement: 步骤 4 中的图像 1,1
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      询问修复机器人
      添加评论
    1. DigiTech RP70  Footswitch Replacement, Footswitches: 步骤 5 中的图像 1,3 DigiTech RP70  Footswitch Replacement, Footswitches: 步骤 5 中的图像 2,3 DigiTech RP70  Footswitch Replacement, Footswitches: 步骤 5 中的图像 3,3
      • Pull firmly on the binder clips that are holding the footswitches in place to remove them.
      • To get the binder clips back in place, you will need to attach handles from another binder clip to hold them open.
      询问修复机器人
      添加评论
    2. DigiTech RP70  Footswitch Replacement: 步骤 6 中的图像 1,1
      • Pull the footswitch down and upwards to remove it from the casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
1指南评论
So what is the fix? Replacing both foot switches with new ones? Or removing them and reinstalling them will fix the problem of them not working at all? What’s Step 7? If you stop after completing Step 6 you now just have a casing without foot switches. What will fix the problem of them not working qt all after removing the foot switches?
Carl - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 1,418
