跳转到主内容
加入维修社区 - 创建账户
Desktop PC Hard Drive Replacement
你所需要的
  1. Desktop PC Hard Drive Replacement, Left Panel: 步骤 1 中的图像 1,1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    添加评论
  2. Desktop PC Hard Drive Replacement: 步骤 2 中的图像 1,2 Desktop PC Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    询问修复机器人
    添加评论
  3. Desktop PC Hard Drive Replacement, Right Panel: 步骤 3 中的图像 1,1
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
    询问修复机器人
    添加评论
  4. Desktop PC Hard Drive Replacement: 步骤 4 中的图像 1,2 Desktop PC Hard Drive Replacement: 步骤 4 中的图像 2,2
    添加评论
  5. Desktop PC Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
    询问修复机器人
    添加评论
  6. Desktop PC Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
    询问修复机器人
    添加评论
  7. Desktop PC Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Slide the hard drive out from the metal casing.
    添加评论
  8. Desktop PC Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the cables from the back of the hard drive.
    添加评论
结论
取消:我没有完成这个指南。
64等其他人完成本指南。
团队
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G5
4 名成员
创作了49篇指南
2指南评论
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - 回复 分享
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 21
过去 30 天: 175
总计 12,440
