跳转到主内容
加入维修社区 - 创建账户
Dell XPS M1530 Wireless Card Replacement
你所需要的
  1. Dell XPS M1530 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
    询问修复机器人
    添加评论
  2. Dell XPS M1530 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Push the switch as far to the right as possible to unlock the battery.
    询问修复机器人
    添加评论
  3. Dell XPS M1530 Wireless Card Replacement: 步骤 3 中的图像 1,2 Dell XPS M1530 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Remove the battery using two hands and pull it away from the computer.
    询问修复机器人
    添加评论
  4. Dell XPS M1530 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
    • Two 4.7mm Philips #1 screws
    询问修复机器人
    添加评论
  5. Dell XPS M1530 Wireless Card Replacement: 步骤 5 中的图像 1,2 Dell XPS M1530 Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Lift the panel up from the indented area.
    • This indent should provide enough grip to remove the panel with ease.
    询问修复机器人
    添加评论
  6. Dell XPS M1530 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
    • One 3.9mm Phillips #1 screw
    询问修复机器人
    添加评论
  7. Dell XPS M1530 Wireless Card Replacement: 步骤 7 中的图像 1,1
    • Lift the card out at an angle and carefully remove it.
    询问修复机器人
    添加评论
  8. Dell XPS M1530 Wireless Card Replacement: 步骤 8 中的图像 1,2 Dell XPS M1530 Wireless Card Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
    • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
    • Note the order of colors for the antenna cables indicated on the card.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jase Sasaki
于01/22/15注册
721 声望
创作了5篇指南
团队
Cal Poly, Team 18-4, Maness Winter 2015 Cal Poly, Team 18-4, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 2,141
