跳转到主内容
加入维修社区 - 创建账户
Dell XPS 720 H2C Memory Modules Replacement
  1. Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: 步骤 1 中的图像 1,2 Dell XPS 720 H2C Memory Modules Replacement, Removing Dell XPS 720 H2C Cover Panel: 步骤 1 中的图像 2,2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
    添加评论
  2. Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: 步骤 2 中的图像 1,3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: 步骤 2 中的图像 2,3 Dell XPS 720 H2C Memory Modules Replacement, Memory Modules: 步骤 2 中的图像 3,3
    • The memory modules are located directly above the XPS processor and are attached to the motherboard.
    • There are notches securing the memory modules onto the motherboard.
    • Push down and outward on the both notches to release each memory module from the motherboard.
    询问修复机器人
    添加评论
  3. Dell XPS 720 H2C Memory Modules Replacement: 步骤 3 中的图像 1,1
    • Carefully remove each memory module from its slot.
    • If you are reseating the memory modules, this is the time to clean them and make sure there isn't any dust build up on the surface.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 4-16, Maness Spring 2013 Cal Poly, Team 4-16, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G16
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 34
总计 1,565
