跳转到主内容
加入维修社区 - 创建账户
Dell XPS 720 H2C Graphics Card Replacement
  1. Dell XPS 720 H2C Graphics Card Replacement, Removing Dell XPS 720 H2C Cover Panel: 步骤 1 中的图像 1,2 Dell XPS 720 H2C Graphics Card Replacement, Removing Dell XPS 720 H2C Cover Panel: 步骤 1 中的图像 2,2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
    添加评论
  2. Dell XPS 720 H2C Graphics Card Replacement, Graphics Card: 步骤 2 中的图像 1,2 Dell XPS 720 H2C Graphics Card Replacement, Graphics Card: 步骤 2 中的图像 2,2
    • Locate the graphics card near the bottom-right area of the computer, just below the XPS processor cooler.
    • Before entering into the "guts" of the computer, make sure you have the computer powered off and unplugged. Following that, you will want to unplug any video cables, including DVI and VGA cables, that are connected to the graphics port on the back panel of the computer.
    • Some DVI cables may need to be unscrewed. This can simply be done by hand.
    询问修复机器人
    添加评论
  3. Dell XPS 720 H2C Graphics Card Replacement: 步骤 3 中的图像 1,3 Dell XPS 720 H2C Graphics Card Replacement: 步骤 3 中的图像 2,3 Dell XPS 720 H2C Graphics Card Replacement: 步骤 3 中的图像 3,3
    • Remove the support underneath the processor cooler by pressing down on the latch at the top of the support and pulling the support towards you.
    询问修复机器人
    添加评论
  4. Dell XPS 720 H2C Graphics Card Replacement: 步骤 4 中的图像 1,1
    • Continue by pressing down on blue tab restraining on the graphics card. In the picture the graphics card is shown to have the fourth blue clip from the top holding it in.
    • Pressing down on this clip will enable you to remove the graphics card from the motherboard.
    询问修复机器人
    添加评论
  5. Dell XPS 720 H2C Graphics Card Replacement: 步骤 5 中的图像 1,1
    • Unplug the cable labeled "P3" on the left side of the graphics card. Be sure to push the plastic pin all the way down and pull firmly.
    询问修复机器人
    添加评论
  6. Dell XPS 720 H2C Graphics Card Replacement: 步骤 6 中的图像 1,1
    • Grab the graphics card with two hands and pull directly outward. The card may not come out smoothly. If this is the case, apply firm and even pressure with both hands.
    • If you are reseating the graphics card, this is the time to clean it and make sure dust has been removed from the socket the graphics card sits in.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 4-16, Maness Spring 2013 Cal Poly, Team 4-16, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G16
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 3,946
