简介
This guide demonstrates how to replace the motherboard in the Dell XPS 15 9575. The motherboard connects all the hardware components in the device and is a critical component. If your Dell XPS 15 is experiencing power issues and you've already checked your battery health, a motherboard replacement might be necessary. To make sure this is the right fix, check the troubleshooting section for specific symptoms such as failure to boot, overheating and power issues.
Check out the Dell XPS 9575 Troubleshooting page for more help narrowing down your issues to the motherboard.
Before you begin this repair, turn off your laptop and unplug it from the charging adapter. As an extra precaution, unplug the battery connector from the motherboard or remove the battery before you start.
你所需要的
Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
Wedge the plastic opening pick in between the aluminum cover and the motherboard.
Gently pull up popping off the cover and revealing the rest of the heat sink.
Use a Phillips #0 screwdriver to remove two screws from the lower corner of the motherboard.
Use the Phillips #0 screwdriver to remove the two 3.2 mm black screws holding down the cover.
Use the tweezers to carefully remove the silver cover from the backboard.
Gently wedge the plastic opening pick in between the display cable and the backboard.
Gently pry up, disconnecting the adapter with the display cable from its bracket.
