跳转到主内容
Dell XPS 15 9520 Battery Replacement
你所需要的
  1. Dell XPS 15 9520 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 Dell XPS 15 9520 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.3 mm-long screws securing the back cover.
  2. Dell XPS 15 9520 Battery Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Dell XPS 15 9520 Battery Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the bottom-left corner of the aluminum back cover and the chassis.
    • Leave the pick inserted before continuing to the next step.
  3. Dell XPS 15 9520 Battery Replacement, Release the corner clip: 步骤 3 中的图像 1,2 Dell XPS 15 9520 Battery Replacement, Release the corner clip: 步骤 3 中的图像 2,2
    • Insert the flat end of the spudger into the gap you just created.
    • Pry up to release the corner clips.
    • Repeat this process for the opposite corner of the back cover.
  4. Dell XPS 15 9520 Battery Replacement, Unclip the front edge: 步骤 4 中的图像 1,3 Dell XPS 15 9520 Battery Replacement, Unclip the front edge: 步骤 4 中的图像 2,3 Dell XPS 15 9520 Battery Replacement, Unclip the front edge: 步骤 4 中的图像 3,3
    • Reinsert your opening pick under the aluminum cover at the front edge of the laptop.
    • Pry to loosen the cover.
    • Pry at multiple locations along the front edge to release all of the retaining clips.
    • Do not use a sliding motion along the front edge. This may damage cables near the trackpad.
  5. Dell XPS 15 9520 Battery Replacement, Remove the back cover: 步骤 5 中的图像 1,3 Dell XPS 15 9520 Battery Replacement, Remove the back cover: 步骤 5 中的图像 2,3 Dell XPS 15 9520 Battery Replacement, Remove the back cover: 步骤 5 中的图像 3,3
    • The edges of the back cover are very sharp. Use caution when handling it.
    • Lift the back cover off the chassis and remove it.
    • If the back cover feels stuck to the chassis, use an opening pick to release any remaining clips around the back cover's perimeter.
  6. Dell XPS 15 9520 Battery Replacement, Disconnect the battery: 步骤 6 中的图像 1,3 Dell XPS 15 9520 Battery Replacement, Disconnect the battery: 步骤 6 中的图像 2,3 Dell XPS 15 9520 Battery Replacement, Disconnect the battery: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  7. Dell XPS 15 9520 Battery Replacement, Remove the tape: 步骤 7 中的图像 1,3 Dell XPS 15 9520 Battery Replacement, Remove the tape: 步骤 7 中的图像 2,3 Dell XPS 15 9520 Battery Replacement, Remove the tape: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers, or your fingers, to peel back the tape connecting the speaker cable and the battery.
    • Repeat for the three other tape segments.
  8. Dell XPS 15 9520 Battery Replacement, Unfasten the battery: 步骤 8 中的图像 1,2 Dell XPS 15 9520 Battery Replacement, Unfasten the battery: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the eight screws securing the battery:
    • Four 4.4 mm-long screws
    • Four 3.4 mm-long screws
  9. Dell XPS 15 9520 Battery Replacement, Remove the battery: 步骤 9 中的图像 1,3 Dell XPS 15 9520 Battery Replacement, Remove the battery: 步骤 9 中的图像 2,3 Dell XPS 15 9520 Battery Replacement, Remove the battery: 步骤 9 中的图像 3,3
    • Lift the battery straight out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
124,744 声望
创作了582篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,303篇指南
一条评论
Thanks Alex, easy to follow
John Carmichael - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 90
总计 2,657
