跳转到主内容
Dell XPS 13 9310 Battery Replacement
你所需要的
  1. Dell XPS 13 9310 Battery Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Dell XPS 13 9310 Battery Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Battery Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Dell XPS 13 9310 Battery Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Battery Replacement, Release the case's front clips: 步骤 3 中的图像 1,2 Dell XPS 13 9310 Battery Replacement, Release the case's front clips: 步骤 3 中的图像 2,2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Battery Replacement, Release the remaining clips: 步骤 4 中的图像 1,3 Dell XPS 13 9310 Battery Replacement, Release the remaining clips: 步骤 4 中的图像 2,3 Dell XPS 13 9310 Battery Replacement, Release the remaining clips: 步骤 4 中的图像 3,3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Battery Replacement: 步骤 5 中的图像 1,3 Dell XPS 13 9310 Battery Replacement: 步骤 5 中的图像 2,3 Dell XPS 13 9310 Battery Replacement: 步骤 5 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. Dell XPS 13 9310 Battery Replacement, Disconnect the battery: 步骤 6 中的图像 1,3 Dell XPS 13 9310 Battery Replacement, Disconnect the battery: 步骤 6 中的图像 2,3 Dell XPS 13 9310 Battery Replacement, Disconnect the battery: 步骤 6 中的图像 3,3
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
    • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
    • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
  7. Dell XPS 13 9310 Battery Replacement, Unfasten the battery: 步骤 7 中的图像 1,2 Dell XPS 13 9310 Battery Replacement, Unfasten the battery: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the five 2.8 mm-long screws securing the battery.
  8. Dell XPS 13 9310 Battery Replacement, Remove the battery: 步骤 8 中的图像 1,3 Dell XPS 13 9310 Battery Replacement, Remove the battery: 步骤 8 中的图像 2,3 Dell XPS 13 9310 Battery Replacement, Remove the battery: 步骤 8 中的图像 3,3
    • Lift the battery straight out of its recess and remove it.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
124,236 声望
创作了581篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 82
过去 30 天: 381
总计 4,612
