简介
Use this guide to replace the battery in your Dell XPS 13 9310 Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
你所需要的
Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
Use a Phillips screwdriver to remove the five 2.8 mm-long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
2等其他人完成本指南。
